Gaskets for fuel tank, Can I use o-rings instead? |
Marlow |
May 24 2004, 09:38 AM
Member Group: Members Posts: 311 Joined: 14-August 03 From: Manassas, VA Member No.: 1,027 |
I'm getting ready to put the gas tank back in the car. The two little red washers that seal the outlet and return tubes on the bottom of the gas tank are in pretty bad shape. I can get them from Pelican for something around 2 bucks but shipping's gonna cost more than the gaskets. Besides it will probably take 2 weeks to get them since they're special order only. Has anyone had luck using rubber o-rings? What about using Viton o-rings?
Any suggestions? I do not want to have to pull the gas tank again anytime soon, will the o-rings last? |
joea9146 |
May 24 2004, 04:39 PM
Senior Member Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None |
The Rubber O rings may not hold up well to the Fuel. Check your local Porsche Dealer
if they still list the part they should be able to get it in a couple of days for you . |
Elliot_Cannon |
May 24 2004, 05:57 PM
Senior Member Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None |
Hi,
I went to the hardware store and found some copper crush washers that worked good. I have also used nylon washers. Both will crush when tightened down and form a good seal. Cheers, Elliot |
Lo-Fi Version | Time is now: 6th June 2024 - 02:11 PM |
