thelogo |
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None ![]() |
http://en.wikipedia.org/wiki/File:1963_Chr..._Hershey_PA.JPG
what are the technical hurdle's involved in turbine automobiles , i know tanks can be turbine powered and i'm sure torque is abundant but milage is poor . Also , Rotary Radial anyone , never even heard of this until yesterday . not a rotary or a radial , but a engine where the whole engine spins ??? some body explain that to me . http://en.wikipedia.org/wiki/Rotary_engine Attached image(s) ![]() ![]() |
jmill |
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest ![]() |
Fokker Triplane had it. Imagine a radial engine where the the crank stays stationary and the entire engine spins around the crank. Works real nice for cooling but it was a bummer to turn in the opposite direction of engine rotation. Turned great with it. Or maybe is was the other way around. Anyhow, lots of pilots crashed because of it.
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
Mike Bellis |
Mike Bellis |
partwerks |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,613 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 ![]() |
I need one of those in my 914. Then I would have the audio effects of being ready for take off........
zymurgist |
"Ace" Mechanic ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None ![]() |
Bartlett 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest ![]() |
http://en.wikipedia.org/wiki/File:1963_Chr..._Hershey_PA.JPG what are the technical hurdle's involved in turbine automobiles , i know tanks can be turbine powered and i'm sure torque is abundant but milage is poor . Also , Rotary Radial anyone , never even heard of this until yesterday . not a rotary or a radial , but a engine where the whole engine spins ??? some body explain that to me . http://en.wikipedia.org/wiki/Rotary_engine I got a ride in one of those cars when I was a kid. It was really cool. It made no noise! |
Pat Garvey |
Do I or don't I...........? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,900 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States ![]() |
I was 17 & working for a pharmacist in northern Kentucky. He had no pull with anyone, but one of these (they said 6 nationwide) was dropped in his lap for a week. I was his delivery boy.
It was ugly! It was cool! It ran on virtually any available fossil fuel. It was reallt quiet! I was not permitted to drive it. Here's what I remember, other than it being ugly. It was very luxurious. It was very quiet. It emitted heat from the rear that was unbelievable & would have fried the radiator of anything behind it (the heat cracked our drugstore window!, which Chrysler replaced! I still remeber the 80+ year old mother of the owner's wife sceaming "get that montrosity out of here before it burns the place down". It was cool at the time (to me), but it was a slug. Wow, I can't believe someone dug this up! Pat |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,204 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Turbines: Low torque, spin to the moon. Kinda like a Wankel on steroids that way. They spin tens of thousands of RPM or better.
They do not like to change speeds, so a direct connection to the drive wheels will not accelerate that well, at least at first, but the top end will be phenomenal. They burn massive amounts of fuel. The rotary was an interesting engine. The prop was bolted to the crankcase, while the crankshaft was bolted to the airframe. The whole thing spun together. It allowed the engine to be much lighter, because the whole thing served as a flywheel. (Early engines often needed weighty flywheels because they ran unevenly and pretty rough.) They had a very odd intake system; I think the fuel was fed into the crankcase through the crankshaft. It went into and then out of the cylinders (through the piston??), then back in again where it was burned. The exhaust valve was on the "head". It was pretty inefficient, but relatively lightweight because as mentioned it didn't need a flywheel. It used a total-loss oiling system, where oil went in and got whirled around with the gas and air in the case, and eventually was expelled out the exhaust. It was castor bean oil, and it gave the pilots the screaming s**ts because they wound up ingesting it. One of the most famous early rotaries was the Gnome Monosoupape. Soupape is the French word for valve, so it was the "one valve" because the exhaust valve was the only visible one. http://en.wikipedia.org/wiki/Gnome_Monosoupape I love some of this early aviation stuff. (IMG:style_emoticons/default/smile.gif) --DD |
Lo-Fi Version | Time is now: 15th July 2025 - 03:35 AM |
