sixaddict |
Senior Member ![]() ![]() ![]() Group: Members Posts: 808 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States ![]() ![]() |
Have hot rod track car GT replica.....Installed front air dam (AAs Ultimate Air Dam...modified for flares) Trying to develop some downforce for high speed turns ...
A: Will it work B. Do I need real lip spoiler for balance Seemed to get differing "opinions" Anybody have real life results? Thanks Terry |
carr914 |
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 119,140 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States ![]() ![]() |
Do you have a rear spoiler? Front & Rear need to work together.
The rear of our cars tend to get light at speed. When you say High Speed Turns, how fast do you mean? T.C. |
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
IMO, a spoler is not as effective as a well designed wing.....but a hell of a lot cheaper.
In SCCA Autocross, most classes are limited to a 10 inch high spoiler and everybody runs the max height....but the top speeds are limited to 75ish mph. My old AX car had a max height spoiler but there is no windshield or rear window.....better air flow to the spoiler. Dunno if I'd go that high for a track car unless I had HP to burn (and a windshield & all)....but it is easier to cut one down than raise the height. May not be pretty enough for a track car. Attached thumbnail(s) ![]() |
sixaddict |
TC;
You kind of answered the question ...front and rear work together ...... At home track CMP "kink" is 110 plus..... Also planning for Road Atlanta in June. I have a rear "lip" spoiler to install....just hadn't decided to "drill" as yet. A big M3 came in with splitter and wing and was able to blow through there "flat out " according to driver.......Not sure my cajonies are sufficient for that or that it is totally accurate but ....... ! Terry Do you have a rear spoiler? Front & Rear need to work together. The rear of our cars tend to get light at speed. When you say High Speed Turns, how fast do you mean? T.C. |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
IMO, a spoiler is not as effective as a well designed wing (IMG:style_emoticons/default/agree.gif) A well designed wing will have less drag and be easier to tune than a spoiler. That airdam will definitely increase high speed grip at the front end, so something that adds downforce (or at least eliminates lift) at the back is advisable. The more HP you have, the more downforce at the rear wheels you can use. I don't think you'll be going as fast in any of the turns at Road Atlanta as the kink at CMP, although a bit of downforce will make you feel more comfortable at both ends of the front straight. |
sixaddict |
Anybody with "well designed" wing drawings or pics would be appreciated. I am in that black hole of mods to go faster ! Front spoiler now means brake ducts and on and on and on .......Trying to do it without trashing the car.
Thanks for the feedback IMO, a spoiler is not as effective as a well designed wing (IMG:style_emoticons/default/agree.gif) A well designed wing will have less drag and be easier to tune than a spoiler. That airdam will definitely increase high speed grip at the front end, so something that adds downforce (or at least eliminates lift) at the back is advisable. The more HP you have, the more downforce at the rear wheels you can use. I don't think you'll be going as fast in any of the turns at Road Atlanta as the kink at CMP, although a bit of downforce will make you feel more comfortable at both ends of the front straight. |
campbellcj |
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,550 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California ![]() ![]() |
My car with front-dam only gets pretty light and bouncy in the rear at 120+ speeds. I spoke with Roger Sheridan at the track recently, and he suggested a 6-inch "flap" spoiler for my car, so I'm planning to start there. He makes gorgeous fiberglass stuff. I can't run a leading-edge wing without taking a hit under POC rules.
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,116 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
Not a road race wing but you get the idea...
Randal |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 ![]() |
Not a road race wing but you get the idea... ![]() Man, that heavy old wing must have added at least 10lbs to your car. (IMG:style_emoticons/default/smile.gif) |
URY914 |
8 pounds. I made it with carbon fiber.
sixaddict |
sixaddict |
This looks like World of Outlaws 914s....Really wild !
race914 |
73 914-4 ![]() ![]() ![]() Group: Members Posts: 1,006 Joined: 31-October 05 From: Nipomo, California (Central Coast) Member No.: 5,027 Region Association: Central California ![]() |
My car with front-dam only gets pretty light and bouncy in the rear at 120+ speeds. I spoke with Roger Sheridan at the track recently, and he suggested a 6-inch "flap" spoiler for my car, so I'm planning to start there. He makes gorgeous fiberglass stuff. I can't run a leading-edge wing without taking a hit under POC rules. Do you need a pic of the Sheridan 6 inch spoiler installed? If so I can go take one & post it. Let me know. |
campbellcj |
Do you need a pic of the Sheridan 6 inch spoiler installed? If so I can go take one & post it. Let me know. A pic would be of interest but not crucial - more importantly (I assume you're using one), did you see a worthwhile benefit from it? FWIW the front spoiler I usually use, as seen in my avatar, is also Roger's and he was aware of that when suggesting the 6" rear to go with it. |
race914 |
Do you need a pic of the Sheridan 6 inch spoiler installed? If so I can go take one & post it. Let me know. A pic would be of interest but not crucial - more importantly (I assume you're using one), did you see a worthwhile benefit from it? FWIW the front spoiler I usually use, as seen in my avatar, is also Roger's and he was aware of that when suggesting the 6" rear to go with it. (IMG:style_emoticons/default/agree.gif) with all above that you need to balance front/rear down force. The sheridan flip spoiler does add rear downforce. Along with it, I use this front airdam with a splitter. ![]() I recommend the Sheridan rear spoiler. |
Heater Guy |
Member ![]() ![]() Group: Members Posts: 74 Joined: 20-October 09 From: Walnut Creek, CA Member No.: 10,960 Region Association: Northern California ![]() |
Anybody with "well designed" wing drawings or pics would be appreciated. I am in that black hole of mods to go faster ! Front spoiler now means brake ducts and on and on and on .......Trying to do it without trashing the car. Thanks for the feedback IMO, a spoiler is not as effective as a well designed wing (IMG:style_emoticons/default/agree.gif) A well designed wing will have less drag and be easier to tune than a spoiler. That airdam will definitely increase high speed grip at the front end, so something that adds downforce (or at least eliminates lift) at the back is advisable. The more HP you have, the more downforce at the rear wheels you can use. I don't think you'll be going as fast in any of the turns at Road Atlanta as the kink at CMP, although a bit of downforce will make you feel more comfortable at both ends of the front straight. I installed a G-stream wing http://www.g-stream.com because I could build my own mounts and install the wing where I wanted it. Most other wings have pre- determined attachment points and must be attached at those points. It has a built in wicker, is very light and a very strong. It also has a very good down force to drag factor. The adjusters make it easy to adjust and fine tune. This wing has is made by Paul Brown (Tiger Racing) that does a lot of race prep for World Challenge Mustangs. ![]() |
Lo-Fi Version | Time is now: 17th June 2024 - 04:12 AM |
