monkeyboy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None ![]() |
I have purchased a bunch of parts from someone local. In the deal was a transmission. I was told it was from a 914, but it doesn't look like any 914 transmission I have ever seen. The mount ears aren't cast in like I am used to seeing. It is a tailshifter, that much I do know.
The cast in numbers are as follows. 901.301.101.0R on top... and on the bottom 90270 and 3080004 I can't find much on it. Can you tell me what the numbers are, and what this trans came from? Thanks. |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Are you sure the bottom is 90270? Usually those numbers are 902/0X, where X is some other number like 902/02.
Attached image(s) ![]() |
monkeyboy |
I can post pictures, but it's definately 902/0. There is nothing else there.
sww914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None ![]() |
That's a type 902/02 aluminum 4 speed from a 911 or 912, or at least it was when it was new. A lot of these parts interchange. I usually build 911 race boxes out of 914 housings because 914s don't have enough horsepower to hurt it.
monkeyboy |
monkeyboy |
sww914 |
If it was a 901 it would be worth a bundle, but it isn't. Check ebay.
Richard Casto |
Blue Sky Motorsports, LLC ![]() ![]() ![]() Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States ![]() |
Link to 901 info on my site...
http://www.blueskymotorsports.com/index.ph...17&Itemid=6 Info I have says the 902/0 is from a 4 speed from a 1965-66 911, 912 Here is a link on PP... http://forums.pelicanparts.com/porsche-912...-4-5-speed.html Says it should have A, H, Q, X gearing. Richard |
monkeyboy |
Thanks everyone. I don't need it so it's time to see if it shifts and start cleaning it up to sell.
Lo-Fi Version | Time is now: 9th July 2025 - 07:31 PM |
