Alternator light on, No volts |
Elliot_Cannon |
May 29 2004, 03:38 PM
Senior Member Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None |
Just put on a new set of Bilstseins and decided to go for a spin. The spin lasted about 15 minutes when the Alt. light came on, voltmeter said 0, the tach. stopped and the oil temp said 0. Other than checking the "V" belt, what else can be done to trouble shoot this problem. Voltage regulator is new.
Cheers, Elliot |
davep |
May 30 2004, 06:50 AM
914 Historian Group: Benefactors Posts: 5,152 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Do a search on alternator. There are lots of threads on similar problems. It could be alternator, VR, relay board or any part of the various pieces of harness. Start using a voltmeter to find out where you can get a voltage.
Strange that you have no voltage, did the engine quit also? If not then the engine is getting power even if the dash is not. DaveP |
skline |
May 30 2004, 06:54 AM
It sounds like all your guages when out at once, I would check the relay board and connections there before I went to other places. That is where everything connects from the engine. Start there. If you need another one to check it, come by and pick one up. I have several of them here.
SLITS |
May 30 2004, 08:28 AM
FUSE #8 AS I REMEMBERThis is what I was advised when I posted the same problem a short time ago and they were right. |
Lo-Fi Version | Time is now: 8th June 2024 - 06:18 PM |
