Engine deck lid installation, Best way to put it back on |
simonr |
May 14 2011, 01:52 PM
Member Group: Members Posts: 65 Joined: 11-July 10 From: Indianapolis Indiana Member No.: 11,925 Region Association: None |
I took my deck lid off to ease my engine removal. I need to get it back on . Whats the easiest way to do this. Trying to get the bolts started while compressing the hinges isnt working for me. My wife wont help me anymore either. There has to be an easier way .
euro911 |
May 14 2011, 03:01 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I know a lot of folks cut out the leading portion of the engine lid hinge brackets, creating a slot, then slide the brackets into the mounting tabs on the firewall with the bolts already partially threaded in ...
Attached image(s) |
Kansas 914 |
May 14 2011, 03:25 PM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
I know a lot of folks cut out the leading portion of the engine lid hinge brackets, creating a slot, then slide the brackets into the mounting tabs on the firewall with the bolts already partially threaded in ... (IMG:style_emoticons/default/agree.gif) I do this to all my 914's and anyone's I work on... |
biosurfer1 |
May 14 2011, 03:37 PM
Teener fo Life! Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
Hm, thats a great idea. I usually just man handle them until I get the bolt going..having a second person helps a lot too, but I'm also tall enough to be on the opposite side of the car from them and reach over.
TheCabinetmaker |
May 14 2011, 04:07 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I know a lot of folks cut out the leading portion of the engine lid hinge brackets, creating a slot, then slide the brackets into the mounting tabs on the firewall with the bolts already partially threaded in ... (IMG:style_emoticons/default/agree.gif) I do this to all my 914's and anyone's I work on... I do it to my cars but never would do it to a customers car.some folks I know would have a shit fit. |
computers4kids |
May 14 2011, 05:38 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
pilothyer |
May 14 2011, 07:04 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
If you don't want to slot the hinge, here is the one man method I use. Set the lid with the hinges resting on top of the brackets. Place a piece (wire, smaller bolt, etc) through into the hinge and the bracket on one side to keep it from sliding off. Put the hinge underthe bracket on the other side and install the bolt. Go to the other side and remove the piece you used and move the hinge to the underside of the bracket and start that bolt. Make the ness. adjustments and tighten the bolts.
914Sixer |
May 14 2011, 07:28 PM
914 Guru Group: Members Posts: 8,900 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Take a board that will go from grille to grill. Use it to rest lid on. Work on getting bolt in one side.
mrgjones |
May 14 2011, 07:49 PM
Member Group: Members Posts: 91 Joined: 23-November 09 From: Monterey Member No.: 11,062 Region Association: Northern California |
I usually just lean over the trunk, balancing the hood on my head until I get the first bolt partially started. It's kinda neat hearing all these solutions that people have come up with.
simonr |
May 14 2011, 07:52 PM
Geat ideas. I love to use my dremel so i think the slots will be in place tommorow!! Thaks to all for the help. This is a very helpful forum
championgt1 |
May 14 2011, 09:16 PM
Don't embarrass me Filmore! Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
Slot the hinge. Loosen the bolts without taken them all the way out. Then you can take off and install the lid in a couple minutes! The best mod I have done to my car.
Dave_Darling |
May 14 2011, 09:33 PM
It can be a little difficult to get the washers on both sides of the bracket if you just slot 'em. It's doable, but I don't remember ever having to fight with the springs to install it before slotting the brackets. Just let the springs push everything in the "all the way open" direction, and start the bolt that way.
--DD |
simonr |
May 15 2011, 02:41 PM
I slotted the hinges today . It took 10 minutes of adjusting it correctly. Its on and completes my project . Thanks again to all who responded
Lo-Fi Version | Time is now: 4th June 2024 - 04:22 AM |
