Quick Question, Fan Motor Support Removal |
kconway |
May 15 2011, 02:19 PM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
Is there a correct way to remove the fan support on the engine shelf? Did you just cut it off and grind it down or is there a way to remove the whole thing? Is there spot welds I should be grinding on? I don't see any?
Kev |
detoxcowboy |
May 16 2011, 09:40 AM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
go easy so you do not leave a hoel,, that is all.
sean_v8_914 |
May 16 2011, 09:54 AM
cut off bracket. drill spot welds on mounting flanges
nathansnathan |
May 16 2011, 10:12 AM
Senior Member Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None |
If you don't need to save what you're taking off, it's better to grind the spot welds than to drill I've found drilling will inevitably go through the part it's welded to to some extent (or all the way), spot weld drill bit or not.
Lo-Fi Version | Time is now: 29th May 2024 - 03:11 AM |
