high beam indicator light, stoped working |
914 shifter |
May 15 2011, 06:15 PM
airhead Group: Members Posts: 266 Joined: 28-August 10 From: ny/nj Member No.: 12,111 Region Association: North East States |
my high beam indicator light is out. i have yet to pull out my gauges
uncharted territory for me. remove screws and pull out ? |
CliffBraun |
May 15 2011, 07:52 PM
Member Group: Members Posts: 252 Joined: 26-April 06 From: San Luis Obispo,ca Member No.: 5,933 Region Association: None |
my high beam indicator light is out. i have yet to pull out my gauges uncharted territory for me. remove screws and pull out ? Pretty sure it'd probably be easier to just slide the gauge out of the sheet metal holding it. It's just held in there by the rubber surround. Check the bulb first and then get out the test light and multimeter to chase it down if that's not it. Bulb seems most likely by far. |
detoxcowboy |
May 16 2011, 09:39 AM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
hard parts is getting to it.. on a scale of 1 to 10 it is a 11/2 difficulty.. Put a towel over your steering colmun so you do not mar your gauges.. I usually just tkae them all out starting on the left.. depends how much wire you have on how far you need to go to get them out.. you actually could do a reach around from the gas gauge after it is out and not have to go so far.. you will see.. remeber what wire goes where..
Kraftwerk |
May 16 2011, 07:42 PM
Member Group: Members Posts: 195 Joined: 6-September 07 From: Bbbbbrroooklynnn Member No.: 8,085 |
You should be able to simply yank the wire from behind the speedo and then replace the little bulb. no need to remove the gauge or anything else. lay down on the floor and look up with a flashlight. on my car it is a green and white striped wire.
Lo-Fi Version | Time is now: 9th June 2024 - 04:01 PM |
