louver material, where to get |
machina |
Jun 2 2004, 05:50 AM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
I need to find or make some louver material for an air outlet, kinda like this one but with straight fins and smaller divisions, like .5" each slat.
anyone know where I can find some material like this already made. actually the grille on our old sub-zero fridge would be perfect but if I start parting out the kitchen, I might get in trouble. thanks, dr Attached image(s) |
seanery |
Jun 2 2004, 07:08 AM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
the first places I would check might be
Hoerr Racing Pegasus Racing If neither of those have them, then maybe they can point you in the right direction. |
JmuRiz |
Jun 2 2004, 07:23 AM
914 Guru Group: Members Posts: 5,434 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Wouldn't it be easier to talk with a hotrod shop and maybe use one of their punches to put louvers in, instead of cutting and welding in a patch? Just a suggestion...unless it's f'glass we are talking about.
maf914 |
Jun 2 2004, 07:55 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
I don't remember the name, but one of the club members has a very pretty monochromatic white 914 with louvers in the rear of the side rocker panels. Perhaps he could offer some info about louver stamping?
seanery |
Jun 2 2004, 08:15 AM
that is Kargeek's car.
John Kelly |
Senior Member Group: Members Posts: 692 Joined: 1-May 03 From: Moclips WA. Member No.: 640 |
If you have a local sheet metal shop, they probably do louvers on occasion. or you can make your own by hand (a bit difficult) Williams low buck tools sells a louver die set for their beader machine as well...not as well defined as a stamped louver:
http://www.lowbucktools.com/louver.html John www.ghiaspecialties.com |
RON S. |
Jun 2 2004, 09:10 AM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
Take your shape to a local fab shop.
I made my cover for the oil cooler opening under my car.I had the louvers punched.It took about all of 10 minutes. Go thru the phone book and call around,some fab fab can do it. Ron Attached image(s) |
Kargeek |
Jun 2 2004, 10:17 AM
Senior Member Group: Members Posts: 555 Joined: 14-March 03 From: Orange, CA Member No.: 430 |
A local company called Sir Michaels here in socal did my louvers. That was 20 years ago! Depending on what you want done, you can send them the part or they can punch the size and width into a specified size of sheet metal. They are still in business- primarily producing custom truck parts. You might want to call them and see what they can do. Or, like what others mentioned- shop the hot rod, custom metal fab shops. Dave H
Sir Michaels Attached thumbnail(s) |
Lo-Fi Version | Time is now: 9th June 2024 - 06:33 PM |
