| 914_1.8t |
Jun 3 2004, 01:02 PM
Member ![]() ![]() Group: Members Posts: 302 Joined: 3-June 04 From: East Bay Member No.: 2,149 |
I am looking for some high temp hose to use with my conversion. I've seen that quite a few people with water cooled are running these from teh radiator to the engine.
I've tried various places with no luck. I would appreciate it if someone can tell me where I can purchase this from. Also, What is the recommended diameter to use for the hose. Thanks. |
| Mueller |
Jun 3 2004, 01:32 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
| 914_1.8t |
Jun 3 2004, 04:01 PM
QUOTE(Mueller @ Jun 3 2004, 11:32 AM) Thanks...I'll try them. |
| Sammy |
Jun 4 2004, 10:00 AM
. ![]() ![]() ![]() Group: Members Posts: 1,190 Joined: 21-January 03 From: Orange, Ca Member No.: 178 |
McMaster Carr sells it too, gates green stripe I think it was.
www.mcmaster.com |
| John2kx |
Jun 4 2004, 10:51 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 502 Joined: 22-August 03 From: Augusta, Ga. Member No.: 1,066 |
This is taken from some spare pieces I have left from a recent Renegade kit:
As marked on hose- "Gates Green Stripe II Heater Hose 1-1/4" MO1170" This one is installed from outlet of radiator to inlet of water pump. Note: this is a I.D. measurement. "Gates Green Stripe II Heater Hose 1" MO2122" This one is used as a return hose from discharge of block (thermostat housing, fill port etc.) to inlet of radiator. Also used at discharge of water pump to inlet on block (2) ea. Note: this is a I.D. measurement. Wall thickness of both hoses measure 3/16". John |
| Sammy |
Jun 4 2004, 11:32 AM
Yup, that's what I used on my conversion, gates green stripe 1" and 1 1/4" purchased from McMaster Carr.
It turned out to be pretty cheep, and I didn't have to pay shipping because I will-called the order. |
Lo-Fi Version | Time is now: 14th April 2026 - 04:53 PM |
