| spare time toys |
Jun 4 2004, 10:14 AM
hooked on grilling food. ![]() ![]() ![]() ![]() Group: Members Posts: 4,059 Joined: 3-April 04 From: West Plano Tx Member No.: 1,884 Region Association: Southwest Region |
I saw a post on here tha said a Boxter 5 spd and a Audt TT/ Pasat v6 trans are the same. Is that correct or did I read it wrong. Just thinking of trans alternitaves. (IMG:style_emoticons/default/beerchug.gif)
| JFJ914 |
Jun 4 2004, 12:48 PM
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States
That's what I heard, 4cyl and 6cyl FWD. I would think that any VAG (VW Audi Group) FWD transmission would have the same case, ratios might be different.
| 75boxster |
Jun 4 2004, 06:20 PM
Member ![]() ![]() Group: Members Posts: 89 Joined: 1-January 04 From: Ft. Collins, CO Member No.: 1,488 |
The cable shift mech. off of a Boxster bolts right up to a Passat/Audi A4 fronttrak 012. Main hurdle I see is the conversion to the hyd. clutch. Either deal with a less than factory style homemade setup or an expensive tilton style pedal cluster.
| Mueller |
Jun 4 2004, 06:58 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
QUOTE Main hurdle I see is the conversion to the hyd. clutch hahahah......that is one of the easiest parts of the conversion, wait till you try and bolt the transmission to an air-cooled /4 or /6 (IMG:style_emoticons/default/laugh.gif) |
| spare time toys |
Jun 4 2004, 09:47 PM
QUOTE(Mueller @ Jun 4 2004, 04:58 PM) QUOTE Main hurdle I see is the conversion to the hyd. clutch hahahah......that is one of the easiest parts of the conversion, wait till you try and bolt the transmission to an air-cooled /4 or /6 (IMG:style_emoticons/default/laugh.gif) Who said anything about Air cooled (IMG:style_emoticons/default/cool_shades.gif) |
| spare time toys |
Jun 5 2004, 09:51 AM
OK here is a teaser for you. I got a line on a wrecked Jetta with a TDI. I drive a Jetta TDI for every day use and am getting 48.6 MPG average. So I know a TDI will bolt up to a VR6 trans. What I am thinking is drop that combo into a streetable 914 and what a tourer it would be. If you never drove a deisel Jetta you need to try one.All kinds of low end and you can put bigger injectors and chip the box and then they get real fun and get well over 45MPG. (IMG:style_emoticons/default/aktion035.gif) and IM paying about .25 a gal. less than gas. (IMG:style_emoticons/default/rocking nana.gif)
| Mark Henry |
Jun 5 2004, 12:31 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Use a Kennedy (KEP) adaptor and it will bolt right up to the stock trans.
I've had a couple of turbo diesels, I like them, thinking of getting the wife one this fall, but it would be about my last choice for my 914. |
Lo-Fi Version | Time is now: 13th March 2026 - 08:26 AM |
