Tires on a 914 stock what size will fit better, running now 185x65x15 |
Tman914 |
May 31 2011, 07:42 AM
Member Group: Members Posts: 136 Joined: 9-December 04 From: "Livermore, Ca" Member No.: 3,247 Region Association: Central California |
Looking to change tire size from 185 x65 x15 to a 195x60 x15 will this work ?
Thestigz06 |
May 31 2011, 07:57 AM
Aspiring Jarhead Group: Members Posts: 238 Joined: 22-February 11 From: Temecula, CA Member No.: 12,749 Region Association: Southern California |
damesandhotrods |
May 31 2011, 08:19 AM
Senior Member Group: Members Posts: 568 Joined: 26-September 10 From: Santa Cruz California Member No.: 12,218 Region Association: Northern California |
At the moment I am running 195x65x15 in the front and 205x65x15 in the rear on 4 lug Fuchs.
underthetire |
May 31 2011, 08:49 AM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Probably, but you didn't specify what rims you are running. I had 195/60 on my Rivi's, and even a 205 in the rear. Don't recommend the 205 on narrow rims. I run 205/50/16's on 16X7's all the way around now.
Tman914 |
May 31 2011, 08:51 AM
Running 4 lug Fuchs i know there 15"x 5 1/2
TheCabinetmaker |
May 31 2011, 10:18 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
The 195's will not hit anywhere. I ran 205x50 on my pedrinis and they rubbed slightly at full turn. 205x60 did not rub.
Tman914 |
May 31 2011, 12:35 PM
Thanks Guys
avidfanjpl |
May 31 2011, 01:12 PM
914 Hemophiliac Group: Members Posts: 720 Joined: 6-April 10 From: Bear, Delaware Member No.: 11,566 Region Association: MidAtlantic Region |
Curt has it down!
(IMG:style_emoticons/default/agree.gif) 205/60-15 do not rub, but make sure your springs don't sag. John |
eric9144 |
May 31 2011, 02:15 PM
Advanced Member Group: Members Posts: 2,734 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
Been running 205/60/15s on my Fuchs for years, no issues w rubbing at all...you will see the speedo spin a bit higher than it should be but if you're really worried about that it can be adjusted by a speedo shop. |
Dave_Darling |
May 31 2011, 02:29 PM
195/50-15 on Fuchs rubbed aft of the shock tower in the front fenders when the steering wheel was turned full lock. It wasn't a real issue because the wheel never gets cranked over that far when moving quickly, but you could definitely see it was rubbing.
All these cars vary slightly, so YMMV. --DD |
Drums66 |
Jun 1 2011, 04:48 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
....195/60/15(you can't go wrong) (IMG:style_emoticons/default/idea.gif)
(IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/flag.gif) (IMG:style_emoticons/default/shades.gif) |
gothspeed |
Jun 1 2011, 05:04 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
I ran 195/60-15 on my old creamsicle LE with original Mahle wheels. The tires looked and fit perfectly (IMG:style_emoticons/default/beerchug.gif) !!!
Lo-Fi Version | Time is now: 15th June 2024 - 11:20 AM |
