Side Shift Rod Boot and Rear Cover Help. |
sgh |
Jun 1 2011, 03:31 PM
Newbie Group: Members Posts: 29 Joined: 25-October 06 From: NE IL Member No.: 7,094 |
Again with a newbie question... I was installing a fresh side shift transmission this past weekend and my knowledgeable project leader pointed out that I am missing the plastic rear cover and the boot that goes attaches to the firewall and the rod flange. I was perusing the Auto Atlanta side and see that it looks like there are more pieces to this puzzle than a rear cover and boot, no?
Can you knowledgeable and experienced folks out there help an new to the 914 world guy? It looks like both the boot and the rear cover have a rubber or plastic strap that attach them to the firewall and transmission respectively. It also looks like another pair of boots attach to the main boot and rear cover. Is that true? What pieces do I need to order to do this correctly? Thank you. |
914werke |
Jun 1 2011, 03:36 PM
"I got blisters on me fingers" Group: Members Posts: 10,140 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
The firewall boot needs no strap it just friction fits the lips on both the rod & firewall. The shift console cover does indeed require a metal "strap" that cinches it tight to the console rim although you can use a hose clamp if you can find one with a big enough diameter
76-914 |
Jun 1 2011, 03:37 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
re: the plastic cover. I bought mine from Pelican about 2 yr's ago. At first I thought it a bit small so I heated it with a heat gun as I held it tightly against the tranny. Once it warmed enough I was able to snap the last corner on. It is tighter than a knat's ass around a rain barrel and has never needed a clamp to secure it. Even after being removed.
914werke |
Jun 1 2011, 04:05 PM
Here is a pic of the OE "strap"
SirAndy |
Jun 1 2011, 04:09 PM
Resident German Group: Admin Posts: 41,677 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
you can use a hose clamp if you can find one with a big enough diameter (IMG:style_emoticons/default/agree.gif) I've been using two large stainless hose clamps connected together for years and that has worked just fine. (IMG:style_emoticons/default/smile.gif) |
sgh |
Jun 1 2011, 04:19 PM
Thanks Rich - he just helped with the firewall boot. (IMG:style_emoticons/default/beer.gif) Is that strap for the shift console cover?
Lo-Fi Version | Time is now: 8th June 2024 - 02:35 PM |
