Accelerator cable, Snapped |
jcambo7 |
Jun 3 2011, 02:13 PM
Senior Member Group: Members Posts: 1,664 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest |
I think my cable freaking snapped on me. (IMG:style_emoticons/default/headbang.gif) I am guessing that it got caught on something or just wore out from rubbing. I will have to look into that. I was trying to start it up and gave it some gas a couple of times and heard a pop and the pedal went to the floor and stayed there. I am trying to figure out if I am going to have to buy a 914-6 cable or if I can use one that is off a 4 cyl. I am assuming the 6 cable is what I need. The engine is a 1970 E 911 2.2 with Zenith carbs.
Tom_T |
Jun 3 2011, 02:22 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Best check that you've got a good ground strap & connections from the transaxle to the chassis (stud on underside of rear trunk), otherwise your acc. cable becomes the ground & fries! (IMG:style_emoticons/default/blowup.gif)
You do have a grond strap there, don't you!? (IMG:style_emoticons/default/poke.gif) |
jcambo7 |
Jun 3 2011, 02:30 PM
Best check that you've got a good ground strap & connections from the transaxle to the chassis (stud on underside of rear trunk), otherwise your acc. cable becomes the ground & fries! (IMG:style_emoticons/default/blowup.gif) You do have a grond strap there, don't you!? (IMG:style_emoticons/default/poke.gif) I have a good ground strap for the tranny. I did just discover after calling a friend that is a mechanic that I have a cable from a 4 cylinder because mine doesn't go to the tranny. I'm still going to make sure it's not rubbing on anything. |
Lo-Fi Version | Time is now: 8th June 2024 - 11:01 PM |
