A/C Hoses, Need hose spec |
mtburman |
Jun 5 2011, 10:18 AM
Newbie Group: Members Posts: 36 Joined: 8-April 10 From: Phoenix Member No.: 11,587 Region Association: Southwest Region |
Does anyone have specs for A/C hoses? Upgrading to Sanden compressor, want to replace hoses but need to ensure I order the correct end fittings since they are custom hoses.
Larry.Hubby |
Jun 5 2011, 08:43 PM
Member who doesn't post much, but has a long time in 914s Group: Members Posts: 186 Joined: 24-November 04 From: Palo Alto, CA Member No.: 3,172 Region Association: Northern California |
Have a look at the on-line catalog of Vintage Air: http://www.vintageair.com/catalog.asp . They have both hard and soft lines and fittings for pretty much everything.
charliew |
Jun 6 2011, 04:33 PM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
There is also a vw new air to old vw's place in calif. Google vw ac. I met Jack Chisenhall in college and ran around with his brother and he is good but not as close as the guy in the west.
SLITS |
Jun 6 2011, 07:54 PM
Most A/C shops that I encountered can use your fittings to make new hoses (assumption is that you have the old ones).
mtburman |
Jun 6 2011, 09:01 PM
got them, AAPAK in phoenix, went in over lunch, out with new hoses. Sanden compressor fitted up. Engine shelf mess cleaned up, may need to add metal depending on compressor fit. Pulling condenser out to have look at metal up front.
Also thinking of replacing clutch since motor is out. |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:53 AM |
