Lifters |
Lifters |
newdeal2 |
Jun 10 2004, 12:08 AM
Unregistered |
A comment was made about lifter replacement when I was asking about rebuilding the top end [pistons, cylinders and heads]. I was looking at the Pelican site and it says not to replace the lifters if you are not replacing the cam. It will cause premature wear...true?
URY914 |
Jun 10 2004, 07:53 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,010 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
You need to replace the cam and the lifters at the same time. If not, one will be harder than the other and will wear at different rates. I have a friend that installed new lifters and it wore the cam lobes down so that they were round. Valves wouldn't open-not good.
Paul |
Bleyseng |
Jun 10 2004, 08:19 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
You replace them is sets. I dunno about the ceramic lifters though, if you can just drop them in.
Geoff |
Jake Raby |
Jun 10 2004, 09:12 AM
Ceramics are indestructible and have a Rockwell hardness of 90. You can run them with any cam, even used and be fine..
Not true with ANY otherlifters. I have swapped them out with good luck in the old days, but these days I would not even consider it! |
Mark Henry |
Jun 10 2004, 09:45 AM
I've done it before (cheap Canadians (IMG:style_emoticons/default/wink.gif) ) BUT I've had the cam out, total spec. inspection and I've polished the cam. Most T4 cams will not pass the spec. inspection, most of the time they are just worn out.
Like Jake said, with the lifter issues we're having I won't do it now. |
Lo-Fi Version | Time is now: 6th June 2024 - 04:18 AM |
