Dual carbs, mounting the accelerator cable |
jsaum |
Jun 9 2011, 09:33 AM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
I'm working on installing a set of EMPI EPC 34's and was wondering where and how the accelerator cable is routed and mounted. I have the mounting bracket and it looks like it could be mounted in several places. If any one can post a picture of their set up that would be a big help.
Thanks, Jsaum |
mikey63 |
Jun 9 2011, 10:04 AM
Member Group: Members Posts: 121 Joined: 30-March 10 From: Windsor,Ca Member No.: 11,529 Region Association: Northern California |
Mine is mounted on the middle of the case running to a hex bar setup.
Attached image(s) |
Elliot Cannon |
Jun 9 2011, 11:40 AM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
Similar hex bar. Different configuration.
Attached thumbnail(s) |
jsaum |
Jun 9 2011, 11:41 AM
mikey63 |
Jun 9 2011, 11:57 AM
Those filters are for the engine venting...wanted to try something.
VaccaRabite |
Jun 9 2011, 06:33 PM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Here is how I did it - made my own bracket:
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.static.flickr.com-1435-1307666014.1.jpg) Zach |
t collins |
Jun 9 2011, 07:28 PM
Advanced Member Group: Members Posts: 3,270 Joined: 21-March 06 From: Virginia Member No.: 5,754 Region Association: None |
zx-niner |
Jun 9 2011, 09:55 PM
Member Group: Members Posts: 294 Joined: 13-June 05 From: Las Vegas, NV Member No.: 4,269 Region Association: Central California |
Seems like everyone has to make their own. My custom linkage setup:
VaccaRabite |
Jun 10 2011, 04:22 AM
The key to the bracket is not allowing it to flex when you stand on the go pedal. IMHO you want the bracket supported by 2 bolts.
Zach |
jsaum |
Jun 10 2011, 08:29 AM
I'm going to start with the same set up as the first picture from mikey63. I'll just get longer bolts and make some spacers to move the cable over abount a half inch, the carbs came with a bracket. If I don't like the way it works I'll fab up someting with the welder. I have another question on the dual carb set up, the Empi intake manifolds have a vacuuum port on each one, is this to balance them should I run a hose to each one?
Jsaum |
Elliot Cannon |
Jun 10 2011, 10:34 AM
These are all pretty good examples of how to set up the carbs. It's very important to have the geometry of the linkage set up properly. The linkages from the hex bar to the carbs must be the same length and same angle. It's very important that the throttle butterflies open at the same time at the same rate. Balance between the two carbs is muy importante. Both carbs should be at wide open throttle at the same time when the throttle pedal reaches the stop. You should also make a effort to not have ANY slop or play in the linkage anywhere. All this makes for great throttle response.
Lo-Fi Version | Time is now: 1st June 2024 - 10:08 AM |
