DRIVER'S SIDE DOOR WON'T OPEN, WONT OPEN FROM INTERIOR SIDE |
914.SBC |
Jun 12 2011, 09:27 AM
Member Group: Members Posts: 248 Joined: 12-December 10 From: CORONA, CA Member No.: 12,479 Region Association: None |
I finished my project and have been enjoying some short drives in town. This morning I went to Starbucks and could not get out of the car cuz the driver side door would not open from the inside. It will open from the outside. I have not pulled the door panel off to inspect what it could be. I am not familiar with the internal door pieces.
If someone might know what and where I need to look internally that would be great. Any idea of what piece might have broken so I can ask around if any one has one..whatever it might be? I have a 1970. Thanks gents... |
McMark |
Jun 12 2011, 09:42 AM
First, try removing the little screw that holds the interior trim 'ring' in place. If that screw is too long, it'll interfere with the handle.
jk76.914 |
Jun 12 2011, 10:02 AM
Senior Member Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
First, try removing the little screw that holds the interior trim 'ring' in place. If that screw is too long, it'll interfere with the handle. (IMG:style_emoticons/default/agree.gif) Yes. Exactly. And along that same vein, if your door handle mechanism is slightly too far back where it screws to the door, the handle will bottom out on that interior bezel before it's gone far enough to unlatch. It'll work fine with no bezel, but not with, so see if removing the bezel fixes the problem (only the one screw). I removed the mechanism (requires removing the door panel), and slightly enlarged the mounting holes, and then remounted it as far forward as it would go in the bigger holes. No idea why I needed to do this, but I did. |
Lo-Fi Version | Time is now: 7th June 2024 - 06:09 AM |
