C71 Hankook tire pressure |
sixaddict |
Jun 12 2011, 06:42 PM
Senior Member Group: Members Posts: 805 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
First use of new AX tires today with ok but not stellar results. Forgot to heat cycle....but need to know recommended pressure....hot cold or both
Using on GT six with 3 liter..245 X 45 X 15 if that helps Thanks Terry |
sixaddict |
Jun 13 2011, 05:32 PM
No one using C71s ?? Makes that decision a murky one !
70_914 |
Jun 13 2011, 06:45 PM
Member Group: Members Posts: 395 Joined: 4-December 09 From: Roy, WA Member No.: 11,096 Region Association: Pacific Northwest |
Isn't tire pressure something that is based on more variables than just tire choice? Weight bias, suspension setup, track layout.... (IMG:style_emoticons/default/confused24.gif)
Tire temperatures across the tread to fine-tune the tire pressure to each car is the best way to go, if I remember correctly my days in formula SAE. |
sixaddict |
Jun 14 2011, 07:31 PM
What you say is not incorrect as you progress to very fine tuning however specific tires have pressures they "like"...just looking for someone running C71s that could help me.
Isn't tire pressure something that is based on more variables than just tire choice? Weight bias, suspension setup, track layout.... (IMG:style_emoticons/default/confused24.gif) Tire temperatures across the tread to fine-tune the tire pressure to each car is the best way to go, if I remember correctly my days in formula SAE. |
sixaddict |
Jun 29 2011, 07:00 AM
Anybody ?? (IMG:style_emoticons/default/sad.gif)
J P Stein |
Jun 29 2011, 08:28 AM
I've never seen them used....not talked to anyone that has (till now (IMG:style_emoticons/default/biggrin.gif) ).
That size is a pretty big cross section for a pretty light car. I'm assuming it is square. I'll assume they are radials & you've got the normal negative camber that radials like. A WAG would be somewhere under 30 psi.....say 26 front-28 rear for 2-3 passes then see whatcha got (temps, roll over, wear). Typically the first pass or 2 is just scrubbig off the mold release.....then they'll get to work. |
Lo-Fi Version | Time is now: 8th June 2024 - 06:35 PM |
