Headlights dont light, Flip up, and back lights work but the headlights dont come on |
Andyrew |
Jun 14 2011, 09:47 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
So my headlights dont work but they flip up and the rear lights come on just fine.
Any idea's? They used to work and they they started coming on and off, and now its nothing. |
partwerks |
Jun 14 2011, 09:56 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
I wonder if there could be some kind of a grounding issue or no??
Like that ghost wipe I had with the intermittent relay. It was just a loose screw under the horn ring that was making it get weird. |
RickS |
Jun 14 2011, 10:19 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Did they work before? Check the fuses and then start swapping relays tp see if yours are bad. After that you need to get technical - which is where I get off the train. Bueller, Bueller?
Andyrew |
Jun 14 2011, 10:52 PM
They used to work, but they they started going out.. Im thinking it could be a ground, but I am not sure which ground it is nor which relays control the lights (not the light motors)
Mike Bellis |
Jun 14 2011, 11:17 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
The ground is right behing the headlights, in the trunk. Fuse 1&2 are high and 3&4 are low. High and low fuses will not both be hot at the same time. Is there power to the fuses with the lights turned on? If so, bad ground or bad bulb. If no power to any of 4 fuses, bad hi/low relay maybe but I bet your problem is back at your ignition. Headlight power is from the ignition switch to the headlight switch to the relay to the fuse to the lamp.
Lo-Fi Version | Time is now: 6th June 2024 - 10:56 AM |
