VDO Oil Pressure Adapter Hose, Who has them? |
76-914 |
Jun 15 2011, 08:02 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Who has the VDO oil pressure relo hose #150 752D? (IMG:style_emoticons/default/confused24.gif) PP mentions them but no listing and German Supply is out of stock. TIA
tradisrad |
Jun 15 2011, 08:24 AM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
Who has the VDO oil pressure relo hose #150 752D? (IMG:style_emoticons/default/confused24.gif) PP mentions them but no listing and German Supply is out of stock. TIA CALL Rich at HPH 650-364-6234. I have read that others are using paint ball hoses. |
tomeric914 |
Jun 15 2011, 09:05 AM
One Lap of America in a 914! Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
76-914 |
Jun 15 2011, 09:40 AM
Nope, at least not metric, anyway. They only stock the 1/8" npt style, currently. |
underthetire |
Jun 15 2011, 11:09 AM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
I used a grease gun hose from ACE hardware.
r_towle |
Jun 15 2011, 11:18 AM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
stainless wrapped air line from a paint ball gun looks better...just find a paint ball store.
rich |
retro74 |
Jun 15 2011, 12:08 PM
Unregistered |
tomeric914 |
Jun 15 2011, 01:14 PM
Nope, at least not metric, anyway. They only stock the 1/8" npt style, currently. Oh, yep, my bad. I bought 3 metric ones from John, the last one being a couple years ago. Thanks for correcting me! |
Cap'n Krusty |
Jun 15 2011, 04:45 PM
Remember, it's 10mm x 1 TAPERED thread, NOT conventional 10x1 straight thread. It's virtually indistinguishable from 1/8 NPT. You could probably cut both with the same tap and never know the difference. The 10mm x 1 straight thread is used in more modern applications, and always with a copper washer. Typical VDO dual post senders for our application have tapered threads and should not be used with adapters having straight 10mm x 1 holes. I suggest a grease gun hose, because they're cheap and readily available. They normally withstand 1500-3000 PSI, so they're substantially overengineered for this use. As always, you'll have to ground the sending unit in order for it to work properly.
The Cap'n |
ChrisFoley |
Jun 15 2011, 06:12 PM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Remember, it's 10mm x 1 TAPERED thread, NOT conventional 10x1 straight thread. It's virtually indistinguishable from 1/8 NPT. You could probably cut both with the same tap and never know the difference. The 10mm x 1 straight thread is used in more modern applications, and always with a copper washer. Typical VDO dual post senders for our application have tapered threads and should not be used with adapters having straight 10mm x 1 holes. I suggest a grease gun hose, because they're cheap and readily available. They normally withstand 1500-3000 PSI, so they're substantially overengineered for this use. As always, you'll have to ground the sending unit in order for it to work properly. The Cap'n (IMG:style_emoticons/default/agree.gif) grease gun hose available at any flaps |
r_towle |
Jun 15 2011, 06:20 PM
again...paint ball gun hose.
Its NPT, it fits, and it does not look like a grease gun hose. As always, ground the sender. Rich |
76-914 |
Jun 16 2011, 08:53 AM
Thx Cap't, Rich 'n Chris. It all makes sense now. The black grease gun hose will match my color scheme, also. Thanks a bunch guys.
Cevan |
Jun 16 2011, 09:16 AM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
again...paint ball gun hose. Its NPT, it fits, and it does not look like a grease gun hose. As always, ground the sender. Rich +1 on the paintball hose. My local store had different lengths so I got one that fit perfectly. I made a metal bracket that attached to the case with one of the case bolts. This way, it was self-grounding, no separate ground wire needed. |
Lo-Fi Version | Time is now: 4th June 2024 - 04:00 PM |
