Alternative to Pertronix? |
914ltd |
Jun 15 2011, 10:33 AM
Member Group: Members Posts: 239 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None |
I have installed at least 20 Pertronix ignitions on mostly stock 914's in my shop. The benefits are limited to dwell and related timing that does not change and eliminating points maintenance. The failure rate has been low but more than I would like, mainly because of 2 that have failed on 1 customers 914 (there have been others). Pertronix says this is a consumer fault by leaving the ignition turned on without the engine running. I don't think stock 914's need MSD and other complicated and expensive ignitions. Do any of you other shop owners or experienced repairers have a trusted points replacement? Thanks! Brad Mayeur
underthetire |
Jun 15 2011, 11:08 AM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
All the Compu-Fire modules have been great. Im not a shop owner, nor do I claim to be an expert.
JmuRiz |
Jun 15 2011, 01:13 PM
914 Guru Group: Members Posts: 5,433 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
I've had a Crane xr700 on mine for years, never had any problems with the ignition...now the carbs on the other hand....haha.
Crash207 |
Jun 15 2011, 01:49 PM
Newbie Group: Members Posts: 17 Joined: 23-May 11 From: United States Member No.: 13,108 Region Association: Rocky Mountains |
I just put a "Hot-Spark" mod in mine. It was $50 on ebay. Had to file the base a bit to get it to fit. Fired right up and ran smother than it ever did before. I was honestly amazed at how easy and effective it is.
Zundfolge |
Jun 15 2011, 02:37 PM
Senior Member Group: Members Posts: 847 Joined: 12-August 07 From: Colorado Springs Member No.: 7,994 Region Association: Rocky Mountains |
r_towle |
Jun 15 2011, 03:14 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
because there is no accessories setting on the key, you have to deal wit this and I suspect any unit will burn up if the key is left on for a long time...even the coil could overheat.
The suggestion I have is to hardwire the stereo via a fused switch that allows the user to turn on the stereo without turning on the key. Rich |
Drums66 |
Jun 15 2011, 03:21 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
Pertronix says this is a consumer fault by leaving the ignition turned on without the engine running. I thought the newer Pertronix units had solved this problem (dunno because mine is an old one that was installed a decade ago and still works fine)? ......I also thought and read that this had been aleviated? (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/popcorn[1].gif)(shouldn't be an issue!) |
markb |
Jun 15 2011, 06:05 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
I prefer the Crane xr700, however the new 2.0 has a Pertronix already installed. If it ever craps out, tho, in goes a Crane.
ChrisFoley |
Jun 15 2011, 06:19 PM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Pertronix in the dizzy and spare points in the glove box for D-jet.
Mallory dizzy for carbs and L-jet. No maintenance; failures are few and far between. I don't like the Crane units much. Besides, I thought they went out of biz. |
swl |
Jun 15 2011, 07:16 PM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
Pertronix says this is a consumer fault by leaving the ignition turned on without the engine running. I thought the newer Pertronix units had solved this problem (dunno because mine is an old one that was installed a decade ago and still works fine)? ......I also thought and read that this had been aleviated? (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/popcorn[1].gif)(shouldn't be an issue!) Last I looked the pertronix II wasn't available for our distributor. |
Cap'n Krusty |
Jun 15 2011, 07:51 PM
I used to sell Crane, but they're hard to get now ad they're complicated to install. I used to work for the guy that prototyped them for Allison. I sell and like Compufire ignitions. If they'll live in a Hardly, they'll work anywhere.
The Cap'n |
Zundfolge |
Jun 15 2011, 09:11 PM
Last I looked the pertronix II wasn't available for our distributor. Look again (IMG:style_emoticons/default/biggrin.gif) |
Derek Seymour |
Jun 15 2011, 09:44 PM
Member Group: Members Posts: 394 Joined: 10-March 09 From: Yucaipa Member No.: 10,151 Region Association: Southern California |
http://www.hot-spark.com/Hot-Spark-SVDA034-3BOS4U1.htm
This is the best solution if you have a newer "brain". However it seems that during the "SMOG Wars" for lack of a better term, Bosch used the type IV as a test bed for FI technology. To sum it up stock is the best solution for any stock motor. IMHO (IMG:style_emoticons/default/smile.gif) |
914werke |
Jun 16 2011, 02:26 AM
"I got blisters on me fingers" Group: Members Posts: 10,116 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Haudiosolutions |
Jun 16 2011, 06:14 AM
Member Group: Members Posts: 215 Joined: 19-October 10 From: Sevierville, TN Member No.: 12,284 Region Association: South East States |
I have a Crane xr700 but it isn't installed. I can't ger the shutter to fit. grrrr
blitZ |
Jun 16 2011, 07:13 AM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
914ltd |
Jun 16 2011, 07:59 AM
I have installed at least 20 Pertronix ignitions on mostly stock 914's in my shop. The benefits are limited to dwell and related timing that does not change and eliminating points maintenance. The failure rate has been low but more than I would like, mainly because of 2 that have failed on 1 customers 914 (there have been others). Pertronix says this is a consumer fault by leaving the ignition turned on without the engine running. I don't think stock 914's need MSD and other complicated and expensive ignitions. Do any of you other shop owners or experienced repairers have a trusted points replacement? Thanks! Brad Mayeur Thank you all! As I said, I've had a limited number of failures with the Pertronix, most are still working fine after many years of service. The customer has agreed to give it another try. Brad |
ThinAir |
Jun 16 2011, 10:27 AM
Best friends Group: Members Posts: 2,543 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
Last I looked the pertronix II wasn't available for our distributor. Look again (IMG:style_emoticons/default/biggrin.gif) This is for non-vacuum advance distributors. Not for stock D-Jet distributor. |
Lo-Fi Version | Time is now: 1st June 2024 - 03:17 AM |
