Limited Slip Differential, Detailed questions |
r_towle |
Jun 14 2004, 04:01 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Hi,
In a previous thread, I asked which was the best LSD... I have done some reading and now I am dangerously educated (not enough to know, but enough to have an opinion) I think that what I need is a disk type true limited slip differential due to the fact that this is a dedicated autocross/track car. Now, yesterday I had alot of fun testing my car and had some success and some surprises. I bought the car with a "locked" differential. That means a welded differential with both drive axles going the same speed no matter what... This made for some quick learning trying to negotiate some of the tight turns in our local autocross course... Luckily I chose wisely and used the 10 plus year old racing slicks for my test day because alot of the rear tires still remains on the pavement....it was the only way to turn (not that theres anything wrong with that) (IMG:style_emoticons/default/wink.gif) (IMG:style_emoticons/default/wink.gif) So....my question, what locking percentage would you recommend for an autocross car with circa 180-200 hp...? 1800 lbs Rich |
TimT |
Jun 14 2004, 04:05 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
go with 80/80. I think with the stock preload is something like 80/20
Is this a stock 901 LSD, or is a Guard unit? |
r_towle |
Jun 14 2004, 04:16 PM
seems that I will go with a guard unit.
Just got off the phone with Guard and he told me go with 40/60 for autocross and adjust up when I go to the track??? Experiences??? |
TimT |
Jun 14 2004, 04:34 PM
We have guard set up the difs 80/80, these numbers are from very respected grand am, and ALMS crews (a mechanic at my friends shop is on his way back from Le Mans).
BUT!! these are not auto-x cars!! they are pure track cars GT3RSR's etc. I dont know much about auto-x set ups I would however listen to Mr Guard, he knows a thing or two!! |
r_towle |
Jun 14 2004, 06:58 PM
thanx
rich |
SirAndy |
Jun 14 2004, 07:06 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
warning, stupid question ahead:
for AX, where you have A LOT of tight corners in either direction, wouldn't a 50/50 split be the best ???? (IMG:style_emoticons/default/confused24.gif) Andy |
seanery |
Jun 14 2004, 07:59 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
accordiang to the GT page, for autocross a torque biasing diff is better than a limited slip. A limited slip is better for a track car.
Brad Roberts |
Jun 14 2004, 08:09 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
80% works fine when you have over 180hp in 1800#.
I do think that a Torque biasing diff would work better in a AutoX car than a plate style, but the torque biasing diff is a TANK compared to a plate style (which translates into engery spent on accelerating/stopping that weight) Go with the 80/80 ramp and adjust your driving for track/AutoX. B |
TimT |
Jun 14 2004, 08:19 PM
Andy... 50/50= 80/80 LOL
the numbers represent the percentage to fully locked in each direction going forward the dif would be 80% locked and on decel it is 80% locked Also I have a tendency to bias my answers based on lots of 911 experience... (going on my 3rd year as a 914 owner) its a good thing to be able to use compression to slow you car... |
SirAndy |
Jun 14 2004, 08:23 PM
r_towle |
Jun 14 2004, 08:43 PM
Danger, Danger...I read more...what a real two sided coin this one...
I have been reading that a torque biased differential would be better for autox....this will be the sole purpose of the car for the near term, and when I feel the problem arise I think that then would be the time for a plate style limited slip differential...... Now which one, and who is Gt?? Rich |
seanery |
Jun 14 2004, 08:48 PM
TimT |
Jun 14 2004, 08:51 PM
GT is guard transmission
They make both plate style, and torsen style diffs.... Each of the diffs have pros and cons... You may not which one is best for you until you try them both |
r_towle |
Jun 14 2004, 09:02 PM
TimT,
Who is the tranny guy in Conn. I was told norwalk area. p car tranny specialist. Rich |
Brad Roberts |
Jun 14 2004, 11:06 PM
Should be Translog. But be careful. He is one of the shops I called when I wanted to know what everyone was doing about the loose pinion races I keep running across in 901/914 boxes. He gave me the wrong answer ("we peen them")
B |
sixerdon |
Jun 15 2004, 07:09 AM
Member Group: Members Posts: 466 Joined: 23-May 03 From: Dartmouth, MA Member No.: 731 |
Rich and Brad,
Translog is no longer in business. Everything was sold at auction the day before the Hershey meet in April. That was Gary Wigglesworth's business. Rich, the guy you are thinking of is Gary Fairbanks in Norwalk, CT. I've been to his shop. He's got it together and services all stock and custom rebuilds for the historic crowd. You can find his ad in Pano under the classifieds. Don |
TimT |
Jun 15 2004, 07:36 AM
Rich, try Gary Fairbanks
ooops someone else already mentioned him |
SteveSr |
Jun 15 2004, 08:41 AM
Member Group: Members Posts: 203 Joined: 7-October 03 From: Knox,In. Member No.: 1,223 |
While on the subject of LSD's,is it possible to remove the diff carrier without tearing the whole transaxle apart? (IMG:style_emoticons/default/confused24.gif) .................ie,....like out of an American rear drive car or truck?
SteveSr |
RON S. |
Jun 15 2004, 11:00 AM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
It is removable on the 901 box.
But in the 915 the diff is flipped,therefore the whole trans must be torn down to get the diff out. Ron |
r_towle |
Jun 15 2004, 03:38 PM
ok,
Gary Fairbanks is the name, thanx I just could not remember. If I can take out the diff and add the TBD, given that the rest of it is already done.....what is involved??? Do I need to shim it somehow??? and where are the specs to do this??? Rich |
Lo-Fi Version | Time is now: 1st June 2024 - 10:53 AM |
