Another FI issue, Surging when warm |
914coop |
Jun 19 2011, 07:38 PM
Member Group: Members Posts: 214 Joined: 5-September 08 From: Minneapolis Member No.: 9,514 Region Association: Northstar Region |
Need more help.
I have a 76 2.0 d-jet. Engine runs fine when first started, after it warns up it starts surging (Jerking) around 3500 rpm's. What I have done so far. - Adjusted valves - Replace Fuel Pressure Regulator - Disconnected TPS, Problem still exists when disconnected. Idles nice at 900 rpm's Any ideas on what else to check? Thanks Irv. |
JeffBowlsby |
Jun 19 2011, 08:54 PM
914 Wiring Harnesses Group: Members Posts: 8,532 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Is that jerking at 3500 rpm while then car is stationery or while going down the road. If while driving, its probably a worn out TPS.
76-914 |
Jun 19 2011, 09:15 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
And can you pass thru 3500rpm; if so does it smooth out?
914coop |
Jun 19 2011, 10:21 PM
It does not seem to smooth out, Although I have not really spent much time pushing it past the point of surging. I will give it a good try tomorrow.
underthetire |
Jun 20 2011, 08:44 AM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Check the mechanical advance on the distributor.
Lo-Fi Version | Time is now: 6th June 2024 - 02:59 AM |
