koni gas adjustable, who makes a threaded collar? |
DanT |
Jun 20 2011, 03:34 PM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
for these so I can get the rear lower (IMG:style_emoticons/default/biggrin.gif)
Attached thumbnail(s) |
DanT |
Jun 20 2011, 03:35 PM
and
Attached thumbnail(s) Attached image(s) |
DanT |
Jun 20 2011, 03:38 PM
to get the back of this down where it should be (IMG:style_emoticons/default/dry.gif)
If I can't sell it, I might as well keep playing with it! (IMG:style_emoticons/default/smile.gif) Attached image(s) |
andys |
Jun 20 2011, 03:44 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
Ground Control up your way makes coilover kits for 914's; can't say specifically about those shocks. Do you want to keep the stock springs?
Andys |
stugray |
Jun 20 2011, 03:56 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I was looking for this very item.
I look forward to a link or a vendor. Next question (related): If I buy the very same shocks shown above and install them, can I put the adjustable threaded collar on later? Stu |
DanT |
Jun 20 2011, 04:16 PM
I have sent an email to Ground Control with the above Shock pics....waiting for their reply. (IMG:style_emoticons/default/smile.gif)
PeeGreen 914 |
Jun 20 2011, 04:47 PM
Ask Jonathan at GPR (IMG:style_emoticons/default/confused24.gif) He should be able to source them for the best price (IMG:style_emoticons/default/beerchug.gif)
andys |
Jun 20 2011, 04:54 PM
I have sent an email to Ground Control with the above Shock pics....waiting for their reply. (IMG:style_emoticons/default/smile.gif) Dan, Jay is the guy you need to talk to @ GC; he knows 914's real well. The coil overs I got from them for my Koni adjustables were very reasonably priced, as I recall. Partially visible in this photo. Andys Attached thumbnail(s) |
ConeDodger |
Jun 20 2011, 05:05 PM
Apex killer! Group: Members Posts: 23,611 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I have sent an email to Ground Control with the above Shock pics....waiting for their reply. (IMG:style_emoticons/default/smile.gif) Dan, Jay is the guy you need to talk to @ GC; he knows 914's real well. The coil overs I got from them for my Koni adjustables were very reasonably priced, as I recall. Partially visible in this photo. Andys Dan, Jay Morris is the owner of GC. He does know 914's. He did the suspension on my 240Z back when they actually had a shop and worked on cars. Now, they just sell suspension stuff he designs. He is up in the foothills near Placerville now. He used to be 5 miles away in Rancho Cordova. Rob |
914werke |
Jun 20 2011, 05:07 PM
"I got blisters on me fingers" Group: Members Posts: 10,124 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Try Paragon
DanT |
Jun 20 2011, 05:17 PM
Rich, thanks, I know Paragon has some sleeves, just want to know if there are any other good sources.
stugray |
Jun 20 2011, 05:41 PM
Which Konis are those in the pics above?
The ones paragon carries are $230 ea. Stu |
MikeSpraggi |
Jun 20 2011, 07:05 PM
Senior Member Group: Members Posts: 781 Joined: 7-February 05 From: Silver Spring, Md Member No.: 3,570 Region Association: MidAtlantic Region |
I used Rebel Racing for my adjustable spring perches. Very reasonable price.
Randal |
Jun 20 2011, 07:07 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Rich has them. I have some ground control rings and at least one sleeve in the garage. Also have some helper springs. |
jmill |
Jun 20 2011, 07:13 PM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
I have Bilsteins and bought the same kit from Clint at Rebel Racing. It looks like it fits both but appears to be designed more for the Bilstein. The threaded collar doesn't stick above the shock body.
r_towle |
Jun 20 2011, 08:55 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Coleman Racing
If you like pieces....enjoy the next two hours of surfing... http://www.colemanracing.com/Adjuster-Slee...Over-P4565.aspx Rich |
jcd914 |
Jun 21 2011, 12:52 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Jay at Ground Control is a good guy to deal with, very sharp too. I had several long talks with him back when they were first starting out in Rancho Cordova, we even had him do some testing for us right after he got his first shock dyno.
No mater who's spring perch kit you buy you will need shorter springs. No one I know of sells a lower perch that allows the spring to go below the welded stop on the shock. Maybe someone does but most just sit on the stop and some have a machined recess that slides over the stop but just far enough to locate the sleeve. I the stock 3 step sleeve that comes with the Koni's and cut the springs on my car to get the ride height and wheel weights I wanted. And no the springs never failed, fell off or caused my suspension to collapse. I auto-crossed regularly and it was my daily driver for 8 years with that set up. When it was up on a lift or jacked up the springs were too short to hold the upper and lower spring perches in place so the perches were safety wired to the spring and I had to pay attention when I let it down and make sure everything was seated. the springs were 165 lbs springs before I cut off maybe 2 coils, I think (not sure, it was 1989). Jim |
Lo-Fi Version | Time is now: 7th June 2024 - 02:55 AM |
