what size screws to install rocker covers ? |
rfuerst911sc |
Jun 22 2011, 04:20 PM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
I have a 1975 914 and I have the OEM metal rocker covers and the plastic covers that are designed to mount over the metal ones. I know OEM install is to use the plastic rivets but I want to use screws. I'm thinking SS phillips head but need to know the size. By eye they look like a # 4 or # 6 by aprox. 3/8 - 1/2 inch long. I know some of you must have used screws to install these. What did you use ?
Cap'n Krusty |
Jun 22 2011, 04:35 PM
I have a 1975 914 and I have the OEM metal rocker covers and the plastic covers that are designed to mount over the metal ones. I know OEM install is to use the plastic rivets but I want to use screws. I'm thinking SS phillips head but need to know the size. By eye they look like a # 4 or # 6 by aprox. 3/8 - 1/2 inch long. I know some of you must have used screws to install these. What did you use ? Well, the holes are 1/8", so you need to use a screw appropriate for that size hole. The Cap'n |
rjames |
Jun 22 2011, 05:43 PM
I'm made of metal Group: Members Posts: 3,954 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Use the plastic rivets. There was someone here selling them, hopefully that's still the case. Do a search.
if you use regular screws, you may be able to see the tops of them from outside of the car when the door is closed. It also looks tacky. I recommend finding the rivets as I eventually did. Ask me how I know. (IMG:style_emoticons/default/biggrin.gif) |
windforfun |
Jun 22 2011, 05:52 PM
Senior Member Group: Members Posts: 1,835 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
rfuerst911sc |
Jun 23 2011, 05:34 PM
Use the plastic rivets. There was someone here selling them, hopefully that's still the case. Do a search. if you use regular screws, you may be able to see the tops of them from outside of the car when the door is closed. It also looks tacky. I recommend finding the rivets as I eventually did. Ask me how I know. (IMG:style_emoticons/default/biggrin.gif) I just sold the rivets I had I didn't care for them. I want to be able to remove them and clean behind them easily hence the screws. |
nathansnathan |
Jun 24 2011, 02:37 PM
Senior Member Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None |
I just sold the rivets I had I didn't care for them. I want to be able to remove them and clean behind them easily hence the screws. It is kind of annoying that you can't get them out, and when you push them through which is the only way, the centers go inside the long iirc. Check out this link, they sell 'plastic rivots' which is what the stock rivot is, but they have what they call 'snap rivots', too. which seem the same, but have a head that looks like it would make it possible to remove them. -says they are black but other colors on request so I guess they could do white hopefully. http://www.plasticsfasteners.com/SnapRivets.html |
Dave_Darling |
Jun 24 2011, 04:48 PM
Just use screws that will hold in a 1/8" hole, as the Cap'n says. You can use a permanent marker to make 'em black, or you can buy ones that are black oxidized. They'll be much harder to see from outside the car, unless your rocker covers are not black.
--DD |
Lo-Fi Version | Time is now: 6th June 2024 - 09:16 PM |
