GAS TANK, inlet- outlet |
VRROOMM1 |
Jun 24 2011, 08:45 AM
Member Group: Members Posts: 117 Joined: 15-July 08 From: mt. dora fl Member No.: 9,302 Region Association: South East States |
dose some one know witch pipe on the gas tank bottom is the inlet and is the outlet? one nerest to the center seam or the farthest? thanks doug
r_towle |
Jun 24 2011, 09:13 AM
Custom Member Group: Members Posts: 24,579 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
outlet is the larger pipe and the inlet has the brass sock in the tank.
Rich |
Cap'n Krusty |
Jun 24 2011, 09:35 AM
The spigot that supplies the fuel to the pump is larger in early cars, and has a "sock" or screen over the pipe where it extends into the tank. The return pipe is smaller in diameter, and doesn't need or have a screen. It's easy to tell by looking inside the tank through the filler neck. Later cars ('75 and '76) have both pipes the same diameter, but the supply spigot still has the screen.
The Cap'n |
VRROOMM1 |
Jun 24 2011, 10:01 AM
The spigot that supplies the fuel to the pump is larger in early cars, and has a "sock" or screen over the pipe where it extends into the tank. The return pipe is smaller in diameter, and doesn't need or have a screen. It's easy to tell by looking inside the tank through the filler neck. Later cars ('75 and '76) have both pipes the same diameter, but the supply spigot still has the screen. The Cap'n thanks that will work |
Lo-Fi Version | Time is now: 23rd May 2024 - 02:30 AM |
