Brake caliper temps..fronts vs. rears, How hot do your calipers get? |
computers4kids |
Jun 27 2011, 05:47 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
Can brake caliper temps be used to help evaluate brake bias front to rear? What do you interpret from the temp readings I took?
I decided to take some temperature readings after some normal driving and braking. Up front, my aluminum brembos with vented rotors were 150 and 151 degrees at 2" from the calipers. My driver's stock rear caliper with solid rotors was 156 while the passenger side was about 120. After seeing the discrepancy on the rears, I rechecked the temps at the rears a couple different times after driving it with the same results. A little info: I have a no proportioning valve and the rear pads are vented at .004. The brakes appear to work good with no pulling. So now I'm questioning how well my back brakes are working. Which rear caliper temps seems correct? I was also interested in my brake bias, but I'm really not too sure if comparing the fronts and rears in this case is of little use. What do you think? Thanks, Mark |
SLITS |
Jun 27 2011, 05:59 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
I think when the rotors glow red they're to hot.
Brake fluid (Dot 4) boils at 350 or 450 (don't remember) Your temps don't seem astounding at all ... And your driver's side caliper is more loaded because of your heavy ass (IMG:style_emoticons/default/poke.gif) Ok ... that's enough for today! |
computers4kids |
Jun 27 2011, 09:22 PM
And your driver's side caliper is more loaded because of your heavy ass (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/av-943.gif) Ron, you truly are wise beyond your years. (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 12th June 2024 - 12:38 PM |
