914/6's with front oil coolers and stock style oil tanks, Please post pictures of oil plumbing in eng comp. |
John |
Jun 29 2011, 08:16 PM
I'm about to re-configure my car (914/6 3.2 conversion).
I have a front mounted oil tank currently and am going to install a factory style tank. I currently have a front mounted cooler. I ran the return line (from the pump outlet) up front to a thermostat, the cooler, and then to the front trunk mounted tank. I plan on relocating the thermostat to the engine compartment then to and from the cooler and then return to the fender mounted tank. I think I have the feed line from the tank to the engine figured out. I am using "-AN" style fittings. Any pics would be helpful. Thanks in advance. |
PRS914-6 |
Jun 29 2011, 10:27 PM
Excellence Magazine Project 914 3.6 Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
Here is a front and rear shot. The left line goes under the gas tank and they both go down the long. Thermostat should be as close to motor as possible
John |
Jun 29 2011, 10:54 PM
Paul!
Thanks! That's exactly what I was looking for. My "return" line already runs up inside the passenger side heater tube. I plan on having the line from the front cooler come back to the rear down the passenger side as well. Can I get you to take a pic of the line connecting to the tank? I didn't realize I could go OVER the engine mount to return to the tank. Thanks and as always more pictures are always welcome. |
Cairo94507 |
Jun 30 2011, 06:45 AM
Michael Group: Members Posts: 9,811 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Paul,
That is a very clean set-up for oil lines. I seriously need to come to Sacramento and see your car. How is your schedule in July? Michael |
J P Stein |
Jun 30 2011, 08:06 AM
Paul! Thanks! That's exactly what I was looking for. My "return" line already runs up inside the passenger side heater tube. I plan on having the line from the front cooler come back to the rear down the passenger side as well. Can I get you to take a pic of the line connecting to the tank? I didn't realize I could go OVER the engine mount to return to the tank. Thanks and as always more pictures are always welcome. My return line went under the mount but tucked up as close as possible. Attached thumbnail(s) |
BKLA |
Really old member Group: Members Posts: 1,253 Joined: 14-August 05 From: OR Member No.: 4,590 Region Association: Pacific Northwest |
here's an image from the modified 911 oil cooler to the DWdesignworks oil tank.
PRS914-6 |
Jun 30 2011, 08:20 AM
A couple more.....
JmuRiz |
Jun 30 2011, 08:53 AM
914 Guru Group: Members Posts: 5,433 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Showoff (IMG:style_emoticons/default/biggrin.gif)
John |
Jun 30 2011, 11:33 AM
Thanks for the pictures guys!
Please keep posting them. I didn't realize that the return to tank line went through the engine shelf, but it makes more sense after seeing it. If I could get a few more pictures showing the return line going through the engine shelf, it would be great. Thanks! |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:18 PM |
