body work question |
914itis |
Jun 30 2011, 11:22 AM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
I am new at doing body work. My question is: do you wet sand before the initial primer?
914.SBC |
Jun 30 2011, 01:08 PM
Member Group: Members Posts: 248 Joined: 12-December 10 From: CORONA, CA Member No.: 12,479 Region Association: None |
I am no paint expert but I have done two cars and never wet sanded. I never even thought to do that. Wet sand after primer before paint and color sand after paint then clear coat.
914itis |
Jun 30 2011, 01:57 PM
Andyrew |
Jun 30 2011, 05:03 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Primer Epoxy? No.
Sand down with 80 grit, sand (if possible) to 180+ prior to spraying primer epoxy (an etching primer used to get a good adhesion base layer to start bodywork on. Dont put water on the car until you are wet sanding the paint. (Unless your sanding primer sealer down to say 600 for a metalic color) |
scotty b |
Jun 30 2011, 05:21 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
Dry sand until the final coat or two of primer/sealer depending on how nice you want the job to be. Wet sand the final coat of primer to 600. You can get away with 400 especially on a solid color, or on single stage paint, but 600 is best. When you go to wet sand the clear or final coat of single stage ( only on soild colors ) start with nothing harsher than 1500 if this is your first time.
Lo-Fi Version | Time is now: 23rd May 2024 - 05:57 AM |
