ahhh finally figured it out!, bucking and missing 2.0 |
ILM914 |
Jul 11 2011, 07:45 PM
Member Group: Members Posts: 96 Joined: 3-March 09 From: NC Member No.: 10,126 Region Association: None |
a while ago i posted for help to figure out why my 74 2.0 was bucking and missing. I got all the usual answers that helped me along the way of eliminating the same. Valve adjustment, Timing, rotor, cap, cylinder head sensor, replaced my petrinix elec ignition module (unneccearily), replaced and tested trigger points. and thought it might be the connection at the trigger point 3 prong plug on the Dizzy. Spark plugs & wires. No one mentioned the dizzy itself. Thanks what is failing. When I push it one way or the other the car runs better. must me slop in the shaft bearings. So glad will report more once good dizzy is in. Can't wait to drive a proper running 914, it's been a long time. Thanks everyone havin her painted soon will also post some pics of the resto Joe H/ ilm914
76-914 |
Jul 12 2011, 08:45 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
(IMG:style_emoticons/default/smilie_pokal.gif) Congrats. Now you are an expert, too. (IMG:style_emoticons/default/smile.gif)
Drums66 |
Jul 12 2011, 11:27 AM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
.....good job bro! (IMG:style_emoticons/default/aktion035.gif)
(IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/flag.gif) |
markb |
Jul 12 2011, 11:38 AM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
Well done!
stugray |
Jul 12 2011, 11:42 AM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
"No one mentioned the dizzy itself."
Um... yes I did. In my post I specifically said: "Turns out the dizzy bearings were bad and the rotor was wearing out the dist cap contacts very quickly". Stu |
ILM914 |
Jul 21 2011, 04:57 PM
Thanks Stu, sorry, I must have misssed that, now it appears the Dizzy I installed may not me working properly. position is more counterclockwise and timing mark from idle to 3500 rpm only moves quarter inch or less, also can't get idle below 1100. Thanks guys, Joe
o I m a while ago i posted for help to figure out why my 74 2.0 was bucking and missing. I got all the usual answers that helped me along the way of eliminating the same. Valve adjustment, Timing, rotor, cap, cylinder head sensor, replaced my petrinix elec ignition module (unneccearily), replaced and tested trigger points. and thought it might be the connection at the trigger point 3 prong plug on the Dizzy. Spark plugs & wires. No one mentioned the dizzy itself. Thanks what is failing. When I push it one way or the other the car runs better. must me slop in the shaft bearings. So glad will report more once good dizzy is in. Can't wait to drive a proper running 914, it's been a long time. Thanks everyone havin her painted soon will also post some pics of the resto Joe H/ ilm914 |
underthetire |
Jul 21 2011, 05:08 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Put some sewing machine oil in the felt under the rotor. See if the advance frees up..
ILM914 |
Jul 23 2011, 10:49 AM
Thanks Jeff I have electronic ignition though I think there's something wrong with this Dizzy though.
v a while ago i posted for help to figure out why my 74 2.0 was bucking and missing. I got all the usual answers that helped me along the way of eliminating the same. Valve adjustment, Timing, rotor, cap, cylinder head sensor, replaced my petrinix elec ignition module (unneccearily), replaced and tested trigger points. and thought it might be the connection at the trigger point 3 prong plug on the Dizzy. Spark plugs & wires. No one mentioned the dizzy itself. Thanks what is failing. When I push it one way or the other the car runs better. must me slop in the shaft bearings. So glad will report more once good dizzy is in. Can't wait to drive a proper running 914, it's been a long time. Thanks everyone havin her painted soon will also post some pics of the resto Joe H/ ilm914 |
dknechtly |
Jul 2 2012, 09:28 AM
Yellow 914 Group: Members Posts: 68 Joined: 11-April 03 From: Wylie, TX Member No.: 560 Region Association: None |
I'm curious, did you ever get this issue resolved?
Lo-Fi Version | Time is now: 28th May 2024 - 11:56 PM |
