4.3L 914 V-6 Price reduced!, Portland, OR. |
rascobo |
Jul 14 2011, 09:59 PM
Member Group: Members Posts: 203 Joined: 26-July 07 From: Portland,OR. Member No.: 7,948 Region Association: Pacific Northwest |
PRICE REDUCED!
I was just completing a extensive mechanical restoration and upgrade when illness (IMG:style_emoticons/default/barf.gif) (IMG:style_emoticons/default/barf.gif) and the loss of My shop pretty much put an end to My ability to finish up. The car runs and drives well. Here is a partial list of what is done and what is yet to be completed; Brakes & Suspension -new rotors and rebuilt calipers on all four corners, including pads,cables, bearings etc. 911 master cylinder -new Bilsteen Sports all around and coilovers w/variable rate Hypercoil springs in the rear -front and rear factory sway bars w/new bushings -4 new 225/14 BF Goodrich on period 14x7 aluminum Turbines -rack spacers - Cooling System -proven all aluminum race radiator and fairing -hi-output thermostatically adjustable electric fan with custom shroud -new hoses -copper coolant pipes -hi-volume aluminum water pump Runs consistently @ 180* -pass. compartment heater & defroster custom built into fresh air box and operated by 914 dash controls Engine & drivetrain -strong and fast GM 4.3 V6 -Edelbrock Performer intake -Competion Cam -Holly 4barrel -new fuel pump & urethane lines -hi-volume oil pump -tubular exhaust manifolds -two MagaFlow Stainless Steel mufflers -newly rebuilt HEI -KEP adapter and new stage 2 clutch package -IMI hi-torque starter -solid 901 w/new seals -new shift bushings (incl. internal shifter seat & cap) -short shifter -new C-V joints Misc. -custom stainless steel motor mounts (front x-member rear extensions) -most bolts and fasteners (80+%?) replaced w/polished S.S. -rebuilt pedal cluster -pass.and engine compartments stripped incl. underside of pan and portions of both trunks -rear half floor pan and portions of firewall replaced (rear window leak) -Hell hole inspected (solid) -Longs opened and inspected (solid) - Engman longitudinal stiffening kit installed -all seams sealed and metal sprayed with 2-3 coats Rust Bullet & 1 coat tiecoat primer -extensive sound deadening in pass. comp. and Zolotone in engine comp. and trunks -new carbon fiber front hood -new tinted windshield -full wiring & electrical system overhaul and upgrade(ask) -custom interior (seats,door panels, dash, console, carpet, etc.) -Notched and dropped Vette C5 leather seats(oh so low) -original Racemark wheel (recovered in goat skin) -custom lighting in all compartments -alarm,stereo,keyless entry -Optima deep cycle battery -PowerMaster polished aluminum 140 amp alternator and on and on...... [u]Now, what's it need? Currently the strongest points are mechanical and the weakest aesthetic. (God, why do pick-up trucks hate Me? (IMG:style_emoticons/default/confused24.gif) ) Fiber glass repairs; both rear flares repaired or replaced,916 front bumper repaired, smooth top repaired, rear trunk lid spoiler -water temp and oil pres. gages installed and minor wiring glitches(ask) -interior resto completed (ask) -alarm, stereo,re-installation -signal lenses cracked -runs great but needs starter flywheel alignment I've owned the car for twenty-two years and know it inside-out and have most every piece yet to be installed in addition many extras. Also receipts & resto pics. Asking $ This post has been edited by rascobo: Jul 31 2011, 07:10 PM |
rascobo |
Jul 16 2011, 11:35 PM
Thanks for the PMs. I'll reply asap.
rascobo |
Aug 16 2011, 04:56 PM
Lo-Fi Version | Time is now: 8th June 2024 - 11:40 PM |
