VW Cup Holder Mod..., using the stock ashtray location |
Eric_Shea |
Jul 22 2011, 03:25 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I had a WTB ad in the classifieds for a stock ashtray as I modified mine for a VW cup holder I found on CIP1.com.
Here's the basics: The cup holder is pretty crude. Basically some PVC and vinyl with a couple of 2x4's cut to give it the proper angle. Crude yes, but actually quite effective. The wood ashtray insert it too large to a 914 so I thought... a 914 ashtray in it's place would be... ummm... perfect. 1. The first step is to disassemble the 914 ashtray. Drill or grind off the rivet heads holing the facia on and the ember guard. Remove everything except the tray. 2. Use a hacksaw to cut through the glue joint on the wood. Hacksaw because there are some nails in there. 3. Drill three holes in the tray section of the 914 ashtray and use the appropriate size wood screws to attach the remaining section of the cup holder to the tray. 4. Insert in dash and enjoy. |
SirAndy |
Jul 22 2011, 03:36 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
pete-stevers |
Jul 22 2011, 06:12 PM
saved from fire! Group: Members Posts: 2,642 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
not sure if i like the look of the vinyl ....but when you have a hot coffee pressed between yer legs....i certainly would appreciate a cup holder...any cupholder!
if you make em make one for a 911 too |
underthetire |
Jul 22 2011, 06:53 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Yahtze cups (IMG:style_emoticons/default/smilie_pokal.gif)
Lo-Fi Version | Time is now: 1st June 2024 - 09:35 AM |
