Eastwood gas tank treatment/sealer ? |
jmmotorsports |
Jul 24 2011, 12:46 PM
Member Group: Members Posts: 308 Joined: 15-August 06 From: Kelso,Wa. Member No.: 6,658 Region Association: Pacific Northwest |
Has anyone here used this stuff ? I have some minor surface rust in my tank,flaky stuff that is plugging my filters and has killed one fuel pump. I would like to hear what people have done to fix similar problems. Jerry |
Krieger |
Jul 24 2011, 01:18 PM
Advanced Member Group: Members Posts: 4,723 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I used whatever kit eastwood sold me around 1995. It was an acid etch and some goopy stuff I poured in and turned my tank around and around. I have never had a problem. Almost forgot, I used some laundry detergent to neutralize acid and prevent flash rust. Follow their directions and you should be good
VaccaRabite |
Jul 24 2011, 04:16 PM
En Garde! Group: Admin Posts: 13,457 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Pull the tank. Take the sending unit out and dump all the crap on the inside out. If you have flakey rust use a length of chain in the tank and shake it around real good to scour the rust flake off. Clean the tank again and inspect it. If it looks good the reinstall it and fill it with fresh gas and be on your way. I would only seal the tank interior if the tank has issues.
The reason I suggest this is that I have read instances of the tank coating comming off over time. This may be application error or product failure. But t results in the end of the tank. Personally I have the Eastwood tank sealing kit on my shelf but I have never used it. |
McMark |
Jul 24 2011, 10:49 PM
76-914 |
Jul 25 2011, 09:31 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Yep, stay away from 1 part "slosh sealants". It was OK in the "Old Gas Days" but no more.
914werke |
Jul 25 2011, 12:51 PM
"I got blisters on me fingers" Group: Members Posts: 10,120 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
RUN, dont walk, away from those solutions .... my .02
whatabout1 |
Jul 25 2011, 02:10 PM
Toys in Red Group: Members Posts: 403 Joined: 6-March 06 From: Charlotte, NC Member No.: 5,676 Region Association: None |
I used a POR15 kit on an old motorcycle and have never had any peeling.
That's using modern gas. |
Vysoc |
Jul 25 2011, 04:21 PM
Vysoc Group: Members Posts: 586 Joined: 27-August 09 From: Young Harris, Georgia Member No.: 10,737 Region Association: South East States |
I used the full POR Kit 2 Summers ago, I had only surface rust in the inside of the gas tank and was going through my complete fuel delivery system. The process called for Step 1, Marine Clean to clean the tank, Step 2, was Metal Ready, and Step 3, was a product called US Sealer. This stuff is nasty as I recall I followed the directions to the letter and it cured up in no less than 72 hours. It all works fine and recently I changed out the gasket between the top of the tank and the expansion tank and was able to look down in the tank through some gas which magnified the inside. Everything was in great order and looked wonderful.....as far as inside of gas tanks are concerned?
I was happy with the system, but it was a 3 part system, if you ever do it make sure you have thick rubber gloves on when dealing with the Sealer, it's silver and I had no intention of touching that crap, next thing you know I thought I was Capt. America with silver hands. For what it's worth, CSN. Vysoc (IMG:style_emoticons/default/flag.gif) |
Lo-Fi Version | Time is now: 3rd June 2024 - 08:25 AM |
