> Ignition Switch terminals..., Which terminal is #30 (+12 battery) ???
streetrover
post Jul 25 2011, 02:50 PM
Hi All,
Here's a pic of the back of the ignition switch and a drawing of the terminal locations. I have a hunch which terminal is #30 (+12v from battery) but I'd like confirmation. (And maybe identify the others as well!)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i221.photobucket.com-11163-1311627019.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i221.photobucket.com-11163-1311627020.2.jpg)
Thanx, (IMG:style_emoticons/default/beerchug.gif)
Bob
Replies(1 - 12)
Dr Evil
post Jul 25 2011, 03:04 PM
Send me your transmission!
Just to be sure, what year is it?
streetrover
post Jul 25 2011, 03:13 PM
Pulled column out of a '74.
Dr Evil
Yes, 30 is Red-12+ in.
50 is yellow to starter (ignition signal)
If you can tell me what numbers are near the terminals I can tell you what color and what they do.
streetrover
post Jul 25 2011, 03:22 PM
OMG!!! It REALLY SUCKS to get old! I went back and inspected the switch with my reading glasses on and, presto, all the numbers were clearly marked. On a good note, the tab that I suspected was #30 by using the ohm meter was indeed correct. So the brain is working ... just not the eyes (guess that's the second thing to go ... LOL!).
MANY APOLOGIES!
Bob (IMG:style_emoticons/default/beer3.gif)
Dr Evil
post Jul 25 2011, 03:24 PM
It happens (IMG:style_emoticons/default/smile.gif)
ThePaintedMan
post Feb 10 2013, 08:06 PM
Oh God, I'm going to get flamed for bringing up and old thread.... but I'm curious anyone can fill in the rest of the diagram from the OP? I would like to know what each of the terminals on the ignition switch is for as I'm re-wiring my car with a cutoff switch, master ignition on, and starter button. I could not find the actual switch in the wiring diagram for a 1973 (which is what my car is). Thanks for you help!
-George
Bob L.
post Feb 10 2013, 08:27 PM
there it is...
I got tired of looking back and forth between the diagram and the legend.
ThePaintedMan
post Feb 10 2013, 09:02 PM
Ah, thank you sir. I'm still not sure I can figure this out, but this helps a lot!
Bob L.
post Feb 10 2013, 11:01 PM
By the way, does anybody know which of the 2 temp sensors in the lower right of the diagram(FI harness) is the oil temp sensor (in the taco plate)?
JeffBowlsby
post Feb 10 2013, 11:19 PM
Temp sensor 2 is the cyl head temp sensor. THe poil temp sensor is not in the FI harness. Its a green/black wire and varies on location depending on model year.
Bob L.
post Feb 10 2013, 11:22 PM
Well, I have a '73 that I'm trying to wire a '76 2.0 into. Soooo.....?
Bob L.
post Feb 12 2013, 01:14 AM
Found it on Part 1 of the diagram as well.
- Lo-Fi Version Time is now: 13th November 2026 - 07:15 AM
