New valve spring suggestions |
-JR- |
Jul 26 2011, 07:25 PM
Life goes faster at 150MPH Group: Members Posts: 276 Joined: 12-May 04 From: Victoria BC Canada Member No.: 2,055 |
I need to replace the springs on my 4cyl-2.2L motor.
I don't need anything exotic, IE dual spring. But the cam makes most of of it's power between 2800--> 6500 RPM and any springs should be rated to withstand 6500 RPM. I don't plan on running the motor higher than that and my rev limiter is also set for 6500. I've had pretty bad luck with the motor so far and would like to put a quality set of springs in rather then taking my chances with any "brand X" springs. I only plan to run the motor until October this year before I start my 6 conversion. Otherwise I would probably go for a dual spring setup. There is a So Cal Imports, and the VW/Porsche dealership but that's about it for any specialized parts places. Thanks! |
stugray |
Jul 26 2011, 08:38 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
yeahmag |
Jul 27 2011, 12:33 AM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I'm not aware of any single spring setup that will hold a performance cam to 6500 RPM. Mine are from Jake and are good to just shy of 6200RPM with one of his cams. My rev limiter has to be set at 6000RPM or I float...
Randal |
Jul 27 2011, 10:44 AM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
I'm not aware of any single spring setup that will hold a performance cam to 6500 RPM. Mine are from Jake and are good to just shy of 6200RPM with one of his cams. My rev limiter has to be set at 6000RPM or I float... Amen to that. Len Hoffman converted my (Hoffman) heads to dual springs that I assume he sourced with Jake. With the dual springs the motor revs to 7K without any issues. Haven't tested the motor beyond that, as the motor was already rolling over. |
Jake Raby |
Jul 27 2011, 12:16 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
We do not have a SINGLE H/D spring thats good past 6,250 RPM. Above that we use dual springs.
You need enough spring to control the valves 500RPM beyond where you intend to rev the engine, because valve loft begins before valve float and can greatly diminish cam, lifter and overall valve train life. Loft is silent, you never know its happening. |
-JR- |
Jul 27 2011, 04:07 PM
Ordered a set of 130 pound springs from FAT this afternoon.
Should do the trick! Thanks Jake for your feed back too. |
-JR- |
Aug 2 2011, 02:33 AM
Worked two nights this long weekend until 1:00am but got the car all apart and back together again. Should be all set for the next Porsche Club event (IMG:style_emoticons/default/driving.gif) *Crossing fingers*
Only installation issue was compressing the springs. The FAT springs were 30% longer than the stock springs and the rocker bar spring compressor I had didn't fit over the spring without a lot of persuasion. My "G" clamp compressor wouldn't work on TYPE IV heads due to the walls of the head being so close to the valve spring. Had a hard time finding cylinder head gaskets for 104.5mm cylinder mating ring. They seem to be pricey at $80 each if you can find them. If it's conducive with forum rules... I'd like to thank Greg at FAT Performance for getting my parts shipped out !FAST! to make my weekend schedule work. They had all the parts I needed in stock ready to ship. |
Lo-Fi Version | Time is now: 1st June 2024 - 12:15 AM |
