WTB: Oil Pressure Relief Crush Washers |
yeahmag |
Jul 27 2011, 10:28 PM
Advanced Member Group: Members Posts: 2,423 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I need the following two crush washers post haste!
N-013-845-2 N-013-829-3 These are the crush washers for both pressure relief pistons on a '74 case. I'll check with Porsche in the morning, but if someone has them and wants to drop them in the mail I'd gladly buy them from you! Thanks. -Aaron |
detoxcowboy |
Jul 27 2011, 10:32 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
yeahmag |
Jul 27 2011, 10:41 PM
Looks like they have one, but not the other. They are listed as:
Oil pressure relief valve crush washer - N 013 829 3 - aluminum, 22mm Oil pressure control valve crush washer - N 013 845 2 - copper, 16mm |
tradisrad |
Jul 28 2011, 07:25 AM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
try high performance house @ 650-364-6234.
I found a 12mm crush washer for my tuna can at Napa Auto parts last saturday (HPH was closed); they may have the larger ones also. |
yeahmag |
Jul 28 2011, 11:58 AM
I just ended up ordering them from Pelican Parts. Thanks.
yeahmag |
Aug 1 2011, 06:11 PM
Turns out Pelican can't get the crush washer for the relief valve below the push rod tubes:
N-013-845-2 Bump again in case anyone has one floating around. I left a message at HPH too. -Aaron |
Lo-Fi Version | Time is now: 11th June 2024 - 02:49 PM |
