Throttle cable, how much slack in cable? |
Java2570 |
Aug 5 2011, 07:29 PM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
Got a 74 2.0L with stock Djet.....
How much play or slack should be normal for my throttle cable? Mine doesn't seem abnormally loose or tight but I have a little problem with my revs dropping at idle when I feather the throttle; it acts like it wants to die. It is much more pronounced when the engine is "cold" or right after starting. I haven't checked the throttle body or much of anything yet. I plan on going through the EFI components soon to test their function; they all were tested by the previous owner and were known to be good at that time; however, things do change without warning. Any ideas on where I should start as it could be a lot of different things......? |
underthetire |
Aug 5 2011, 07:47 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Think your aar isn't working if it does it right after starting cold. The engine should be ~1500-1800 rpm on cold starts, dropping over the next 5 minutes or so to 950. Throttle cable should just be loose enough not to bind when closed.
Lo-Fi Version | Time is now: 7th June 2024 - 11:47 PM |
