914 Electical Problems, Passenger side no lights work |
RCTN914 |
Aug 7 2011, 05:13 PM
Newbie Group: Members Posts: 2 Joined: 7-August 11 From: Knoxville, TN Member No.: 13,414 Region Association: South East States |
Fixing up a 1973 914. When you turn the lights on everything on the driver side works, but on the pasenger side only the headlight on high beam works and the brake light when applied. None of the signal lights, parking lights, reverse lights work. Where do I start? Greatly appreciate any guidance
Mike Bellis |
Aug 7 2011, 05:46 PM
Start at the fuse panel. look for corrosion. Spin the fuse in the holder to make better contact.
RCTN914 |
Aug 7 2011, 06:11 PM
904svo |
Aug 7 2011, 06:48 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
You for got to say if it's the front or rear lights that don't work. I either case check your ground connection ( brown wires) there is two for the front (left and right side). If it's the rear the brown wire multiple may be open.
Dave_Darling |
Aug 7 2011, 10:45 PM
Or a single ground point that has multiple wires going to it might be bad...
--DD |
dlestep |
Aug 7 2011, 10:52 PM
I am smilin'... Group: Members Posts: 890 Joined: 15-January 08 From: Sunrise Florida Member No.: 8,573 Region Association: South East States |
...or tell the fat girl to get out of the passenger seat, she's shortin' out the
seatbelt buzzer harness... |
Lo-Fi Version | Time is now: 8th June 2024 - 04:29 AM |
