4 lug fuch - are they all hub centric ? |
jimkelly |
Aug 10 2011, 10:38 AM
see pic - is this hubcentric?
Attached thumbnail(s) |
Ian Stott |
Aug 10 2011, 02:40 PM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
I have straight and true authentic four bolt Fuchs rims with new very well balanced tires and when I installed the concentric centering rings that I got from Chris Foley the little vibration I had went away.
Ian Stott Moncton Canada |
r_towle |
Aug 10 2011, 02:54 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I think they are all hub centric.
They were not introduced until the hub centric rotor in mid 72. rich |
mgphoto |
Aug 10 2011, 06:21 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
I believe that the initial run of the wheel part number 914 361 011 00 was not hub centric, they were replaced by the factory with part number 914 361 011 01 which is the hub centric version seen in the photo.
jimkelly |
Aug 11 2011, 05:11 AM
does anyone know if hub centric size on 4 lug the same as on 5 lug ?
diameter and depth thanks jim |
JFJ914 |
Aug 11 2011, 09:33 AM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
Tom_T |
Aug 23 2011, 07:46 PM
I believe that the initial run of the wheel part number 914 361 011 00 was not hub centric, they were replaced by the factory with part number 914 361 011 01 which is the hub centric version seen in the photo. (IMG:style_emoticons/default/agree.gif) That's correct info. - they were NOT all hubcentric. They actually ran the BO Recall in 72 Aug - Dec production to check that the hub-centric 2L wheels were put on the new 73's with hubcentric front hubs! Similarly for the Pedrini & Mahle wheels, which were a different Recall ident. which you can see on Jeff Bowlsby's 914 website page for recalls- http://www.bowlsby.net/914/Classic/Recalls.htm The ones in your pic above appear to have the machined inset to receive the hubcentric lip, allowing the wheel to seat properly & flat against the hub/disk. Here's a pic I did to i.d. the right wheel type - |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:15 AM |
