| p914 |
Aug 12 2011, 10:52 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 518 Joined: 7-September 03 From: Sunny South Florida Member No.: 1,117 Region Association: None |
Would 2 1000 cfs fans in the engine compartment mounted on the firewall aimed downward (not an extreme angle) and at the rear of the engine cool engine temps?
What other methods besides Nickys, Shrouds, Radiators are there? |
| johannes |
Aug 12 2011, 11:12 AM
Club Porsche 914 France member since 2005 ![]() ![]() ![]() ![]() Group: Members Posts: 3,092 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France |
First question you should ask yourself is why does this engine run too hot ? Heat that was not created has not to be dissipated.
| p914 |
Aug 12 2011, 11:20 AM
A good question to ask. I should probably say this topic would be relevant to 2.0L and larger engines. Seems that the engine temps have always run hot on the TypeIV. My hot range is defined as engine temps (not oil) over 240 F.
So this would be a discussion of methods to help cool the engine temp other than what I listed above. |
| VaccaRabite |
Aug 12 2011, 11:25 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
240? That's not even operational temp. Heads should be between 270 and 370 ideally.
| FourBlades |
Aug 12 2011, 11:28 AM
From Wreck to Rockin ![]() ![]() ![]() ![]() Group: Members Posts: 2,056 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States
Mount an additional oil radiator with fans. Many threads on this. Doubt you could get enough airflow difference for additional engine bay fans to help much. John |
| Bartlett 914 |
Aug 12 2011, 11:52 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Lean conditions also make the motor run hot.
| r_towle |
Aug 12 2011, 11:54 AM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
The stock fan is only going to pull a certain amount of air.
Adding colder air would be the way to fix any issue. You can add cooler air by adding a front mounted oil cooler, or possibly adding more side vents ala the boxster. At the end of the day you have XXX amount of heat,so you need YYY amount of air that is cooler than that to dissapate the heat. If you have enough air going by the heads, it does not need to be super cool, just a few degrees will enable a transfer. The stock fan is limited in how much is can draw/push...so that is the limitation of volume. Given the limitation of volume (and the design flaws in the stock system) you need a lower temp of air to enable more cooling. Foley has created a new version of the top mounted fan which seems to keep his 2.0 liter race motor plenty cool on the track. Ask him about some of the temp number...he has test data to prove his system is pretty good. Rich |
| p914 |
Aug 12 2011, 01:32 PM
Foley has created a new version of the top mounted fan which seems to keep his 2.0 liter race motor plenty cool on the track. Ask him about some of the temp number...he has test data to prove his system is pretty good. Rich I saw his system and it's a combo of shroud and fan. http://www.tangerineracing.com/engine.htm#...an%20Conversion I'm sure it works efficiently. The only caveat is $1600 I also saw Jake's DTM shroud at @$600 These are pretty well documented. Any other methods out there? |
| p914 |
Aug 12 2011, 02:01 PM
| VaccaRabite |
Aug 12 2011, 05:33 PM
240? That's not even operational temp. Heads should be between 270 and 370 ideally. So 270-370 could be used as a norm for most 2.0L engines for this discussion? For head temps, yes. Oil temps you don't want to see above 220, and mine usually hover around 205. There is NO head temp gauge on a 914 stock. The engine temp gauge is oil temps, not head. Zach |
| p914 |
Aug 12 2011, 06:01 PM
QUOTE QUOTE So 270-370 could be used as a norm for most 2.0L engines for this discussion? For head temps, yes. Oil temps you don't want to see above 220, and mine usually hover around 205. There is NO head temp gauge on a 914 stock. The engine temp gauge is oil temps, not head. Zach Mine's not stock. I have an SDS EFI and the CHT gives a head temp reading. I use a dipstick thermometer for my oil temps. I'd like to know if there's any other methods for keeping the engine temp (head temp) cooler other than the aforementioned. |
| 904svo |
Aug 12 2011, 06:35 PM
904SVO ![]() ![]() ![]() Group: Members Posts: 1,129 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
240? That's not even operational temp. Heads should be between 270 and 370 ideally. So 270-370 could be used as a norm for most 2.0L engines for this discussion? If you are running hotter than 370 degrees your timing is to advance too much. Install a EGT gauge and check the exhaust temp, if its over 1100 degrees change your timing if you don't want melted pistons and drop your valves sets. Check this site out. http://www.thesensorconnection.net/content...and-information |
| 76-914 |
Aug 12 2011, 07:12 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,876 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Would 2 1000 cfs fans in the engine compartment mounted on the firewall aimed downward (not an extreme angle) and at the rear of the engine cool engine temps? What other methods besides Nickys, Shrouds, Radiators are there? Might want to get some ballast. Those 2 1000 cfs fans should get you some air. As in HoverCraft. (IMG:style_emoticons/default/shades.gif) |
| Jake Raby |
Aug 12 2011, 07:59 PM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
I have a pair of the "twin barrel" upper plenums that we sourced for test work.. They are new, no use for them. 250.00
Only good for AX IMHO |
| p914 |
Aug 12 2011, 08:11 PM
[/quote] Yeah, my mistake 2 1000cfm not cfs. (IMG:style_emoticons/default/drunk.gif) |
| Jake Raby |
Aug 12 2011, 08:32 PM
But at very little velocity.. Electric solutions are very poor, I'd almost give the ones away that I have.
| SGB |
Aug 12 2011, 10:22 PM
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
I've wondered about something simple-
scoop like deflectors underneath instead of the flat flaps... maybe create a venturi type panel along the insides of the sail panels to get some value out of that huge vacuum created by the roof to trunk interface... (IMG:style_emoticons/default/beer.gif) |
| Joe Owensby |
Aug 15 2011, 06:29 PM
JoeO ![]() ![]() ![]() Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States |
As someone mentioned, check your timing. Also, with a SDS, you can adjust the air/fuel ratio if needed. If you have the correct a/f ratio and timing, then there is something else wrong. There are several threads here that comment on adding an external oil cooler. I have done so, using a Mocal cooler with an added fan. Not too expensive, and works great. I have photos posted somewhere on the site. The Mocal adapter has build in thermostat, so the system is pretty much self maintaining; allows quick heat ups, but keeps maximum temps down. This was for my car, which tended to run a little warm on 100 degree days when I had the AC running. The Mocal unit gave about a 20 to 25 degree drop in max oil temps. I have also seen that there is at least a little correlation between oil temps and max head temperatures, although head temps can vary a lot depending on engine loads, etc. as well as mixtures. JoeO
| 904svo |
Aug 15 2011, 07:28 PM
Here is how I cooled my 914 engine.
| p914 |
Aug 15 2011, 10:16 PM
I have an external oil cooling system I'm looking and my engine temp is not extremely high. It runs around 270 (from the CHT connected to my SDS). Oil temps run between 220 and 240 on the high side. So, I'll get to the cooler at some point.
That's an interesting shroud 904svo. Did you notice any lower temps using it? The point of this thread was to create a resource thread so people could use the info when they had issues and also for me to learn more. |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:08 PM |
