Razorbobsr |
Member ![]() ![]() Group: Members Posts: 282 Joined: 6-June 10 From: Terre Haute Ind Member No.: 11,813 Region Association: Upper MidWest ![]() |
Getting my car back from Porsche guy, drove 70 miles to home just fine. Get off interstate and engine stalls, hit key and nothing!!! Tach pegs at 7000 but no starter engagement, do have hot start kit. Car ran GREAT all the way home. Ideas? Help needed!! Thanks Bob
Drums66 |
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region ![]() |
......Take it back....Who knows what they touched? (IMG:style_emoticons/default/idea.gif)
(IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/bye1.gif) |
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
Similar Problem Someone Had Last Week!
His didn't have the same no starter engage but maybe a fuse, wire or ign switch. |
Razorbobsr |
......Take it back....Who knows what they touched? (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/bye1.gif) This prob is typical to the 914 according to Hussy at A/A, they sell a hot start kit that sometimes will fix it, but not in this case. Now I am looking for the next best fix. Bob |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Could be ignition switch ... they crack and all sorts of crap happens ... lots of heat in that little plastic switch ... new ones don't last for crap.
Good luck. |
Tom |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None ![]() |
An easy way to cut the problem in half is:
Remove the large yellow wire from the starter solenoid and check for 12 volts between that wire and ground when trying to start. If you have 12 volts, then there is probably a starter solenoid problem. Gently tap the solenoid, hook up the yellow wire, and try again, sometimes the heat causes the solenoid to bind and not connect the batt to starter contacts. If greatly less than 12 volts, (Less than 9 volts), you have a connection problem between the key switch and the starter solenoid yellow wire. Possible ground problem also, check negative batt terminal and large ground strap at transmission. In case you are not aware, the solenoid does two things; moves the starter motor gear out to connect with the flywheel, and makes two electrical connnection with two large contacts to give the starter motor the voltage and current to turn the starter motor. Tom |
Ductech |
Member ![]() ![]() Group: Members Posts: 356 Joined: 16-July 10 From: AridZona Member No.: 11,949 Region Association: Southwest Region ![]() |
my car did this when i had a relay go bad due to water contamination. The relay was sucking up a bunch of juice to the point where the motor wouldn't crank. The thing that reminds me of my instance is that my tach would go to 7 grand when trying to crank over. Granted I have added a bunch of extra relays due to my subie conversion.
But in any of the relays that come on when the key is in the on position could be causing this possible in my humble opinion. (IMG:style_emoticons/default/beer3.gif) |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,200 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Tach pegs at 7000? That's an ignition problem. That and the no-start together sound a lot like an ignition switch problem.
--DD |
Razorbobsr |
An easy way to cut the problem in half is: Remove the large yellow wire from the starter solenoid and check for 12 volts between that wire and ground when trying to start. If you have 12 volts, then there is probably a starter solenoid problem. Gently tap the solenoid, hook up the yellow wire, and try again, sometimes the heat causes the solenoid to bind and not connect the batt to starter contacts. If greatly less than 12 volts, (Less than 9 volts), you have a connection problem between the key switch and the starter solenoid yellow wire. Possible ground problem also, check negative batt terminal and large ground strap at transmission. In case you are not aware, the solenoid does two things; moves the starter motor gear out to connect with the flywheel, and makes two electrical connnection with two large contacts to give the starter motor the voltage and current to turn the starter motor. Tom |
Razorbobsr |
Tom |
When you said moving the solenoid wires slightly and then it started, that points directly to a defective connection. Check those lugs well where they are crimped on. If suspect, crimp on a new spade lug on that yellow wire. Unless you have a built engine, you really do not need a high torque starter. Most all of the problems with these cars are bad grounds, suspect connections, etc, not the starter itself. No one else I know does this but, removing the starter and solenoid and removing the solenoid from the starter and cleaning it and lightly lubing , then wiping the solenoid plunger and plunger cavity will greatly improve the performance of the starter.
While it is apart, check and clean the contacts for the starter current at the rear end of the solenoid also. Tom |
Jeffs9146 |
QUOTE No one else I know does this but, removing the starter and solenoid and removing the solenoid from the starter and cleaning it and lightly lubing , then wiping the solenoid plunger and plunger cavity will greatly improve the performance of the starter. I have done this and it does help with the hot start problem, but it is only temporary if your starter or solinoid is going bad. |
Lo-Fi Version | Time is now: 12th July 2025 - 11:26 AM |
