Aftermarket FI Fuel pressure regulator, Anyone has any experience with? |
Valy |
Aug 16 2011, 12:38 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
I'm going to rise a bit the fuel pressure on my L-Jet as it will go from 1.8 to 2056.
I found those regulators on ebay. http://cgi.ebay.com/ebaymotors/BLUE-JDM-FU...#ht_2373wt_1073 Any experience with it? Pro/Cons anyone? Is the vacuum port negative or positive compensation? Thanks. |
jimkelly |
Aug 16 2011, 01:53 PM
check, jegs or summit, and you may want a liquid filled guage?
that said, i have no experience with the reg you are asking about. doesn't a stk reg have an adjstment screw? jim |
Mike Bellis |
Aug 16 2011, 02:24 PM
It is a cheap POS but, I have used one before with moderate resutls. Buy an Aeromotive regulator if you want it trouble free.
Valy |
Aug 16 2011, 05:02 PM
ConeDodger |
Aug 16 2011, 09:10 PM
Apex killer! Group: Members Posts: 23,614 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Not needed either... Most stock FPR are far superior to anything the aftermarket has to offer.
Valy |
Aug 16 2011, 09:13 PM
ConeDodger |
Aug 16 2011, 09:15 PM
Not needed either... Most stock FPR are far superior to anything the aftermarket has to offer. I can't increase the pressure with stock L-jet FPR. You can with a stock DJet FPR though... (IMG:style_emoticons/default/smile.gif) |
Mike Bellis |
Aug 16 2011, 09:42 PM
It is a cheap POS but, I have used one before with moderate resutls. Buy an Aeromotive regulator if you want it trouble free. Mike, POS means it will not hold constant pressure or that the pressure is not correct or leaks? I just need it to run about 35 PSI. You should be able to use it to hold 35psi. Taks all the fittings out and use teflon tape on them. In fact replace all the fittings with brass ones from home depot. Mount it on your return line before it goes back to the tank. Mount a seporate gauge on the supply line to monitor actual rail supply pressure. You will need to fab a mounting bracket for it. Do not let it bounce around. The pipe threads are a Chinese interpretation on NPT threads. Use lots of tape and put it on so it tightens the tape as you tighten the fitting. |
Mike Bellis |
Aug 16 2011, 09:44 PM
Cap off the vacuum fitting. You only need it for a turbo or supercharger. Not sure if it even works.
Lo-Fi Version | Time is now: 10th June 2024 - 11:24 AM |
