911 Cam Towers--Worth anything?, I have about 12 sets, what should i look for? |
hwgunner |
Aug 16 2011, 07:43 PM
914 Parts @ Discount Prices 800.321.5432 Group: Members Posts: 1,714 Joined: 11-November 04 From: Santa Maria, Ca Member No.: 3,095 Region Association: None |
Are 911 cam towers worth anything. I looked on ebay and they run the gammit but none have sold for a while. Is there a particular type that is worth more than others? what should i look for. Are they worth $20.00 a set? Let me know.
jonathan (IMG:style_emoticons/default/beerchug.gif) |
J P Stein |
Aug 16 2011, 09:37 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
I've never had any luck selling em'. Aluminum scrap value?
Elliot Cannon |
Aug 16 2011, 10:06 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
Is this something Krusty would know? Yo, John! Howboudit?
pcar916 |
Aug 16 2011, 10:16 PM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
They last a long time. If you're building a 3.4L motor the 3.2L towers are better because the later cam bearing journals are bigger than the 3L versions.
Good luck! |
hwgunner |
Aug 16 2011, 10:34 PM
They last a long time. If you're building a 3.4L motor the 3.2L towers are better because the later cam bearing journals are bigger than the 3L versions. Good luck! I am pretty sure they are all earlier versions. Is there an easy way to tell the 3.2 ones? If there is I will go through them and save those. Looks like most are scrap though. jonathan (IMG:style_emoticons/default/beer.gif) |
IronHillRestorations |
Aug 17 2011, 07:52 AM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
You might give EBS a call. They might need some good cores.
Lo-Fi Version | Time is now: 10th June 2024 - 06:17 AM |
