Are 911 cam towers worth anything. I looked on ebay and they run the gammit but none have sold for a while. Is there a particular type that is worth more than others? what should i look for. Are they worth $20.00 a set? Let me know.
jonathan
J P Stein
Aug 16 2011, 09:37 PM
I've never had any luck selling em'. Aluminum scrap value?
Elliot Cannon
Aug 16 2011, 10:06 PM
Is this something Krusty would know? Yo, John! Howboudit?
pcar916
Aug 16 2011, 10:16 PM
They last a long time. If you're building a 3.4L motor the 3.2L towers are better because the later cam bearing journals are bigger than the 3L versions.
Good luck!
hwgunner
Aug 16 2011, 10:34 PM
QUOTE(pcar916 @ Aug 16 2011, 09:16 PM)
Good luck!
I am pretty sure they are all earlier versions. Is there an easy way to tell the 3.2 ones? If there is I will go through them and save those. Looks like most are scrap though.
jonathan
IronHillRestorations
Aug 17 2011, 07:52 AM
You might give EBS a call. They might need some good cores.
