911 Cam Towers--Worth anything?, I have about 12 sets, what should i look for? |
hwgunner |
Aug 16 2011, 07:43 PM
914 Parts @ Discount Prices 800.321.5432 Group: Members Posts: 1,714 Joined: 11-November 04 From: Santa Maria, Ca Member No.: 3,095 Region Association: None |
Are 911 cam towers worth anything. I looked on ebay and they run the gammit but none have sold for a while. Is there a particular type that is worth more than others? what should i look for. Are they worth $20.00 a set? Let me know.
jonathan (IMG:style_emoticons/default/beerchug.gif) |
J P Stein |
Aug 16 2011, 09:37 PM
I've never had any luck selling em'. Aluminum scrap value?
Elliot Cannon |
Aug 16 2011, 10:06 PM
Is this something Krusty would know? Yo, John! Howboudit?
pcar916 |
Aug 16 2011, 10:16 PM
They last a long time. If you're building a 3.4L motor the 3.2L towers are better because the later cam bearing journals are bigger than the 3L versions.
Good luck! |
hwgunner |
Aug 16 2011, 10:34 PM
They last a long time. If you're building a 3.4L motor the 3.2L towers are better because the later cam bearing journals are bigger than the 3L versions. Good luck! I am pretty sure they are all earlier versions. Is there an easy way to tell the 3.2 ones? If there is I will go through them and save those. Looks like most are scrap though. jonathan (IMG:style_emoticons/default/beer.gif) |
IronHillRestorations |
Aug 17 2011, 07:52 AM
You might give EBS a call. They might need some good cores.
Lo-Fi Version | Time is now: 18th May 2024 - 11:20 PM |
