can i run 2.0 out of car without relay board?, & do i have these wires marked correctly ?? |
jimkelly |
Aug 17 2011, 08:44 AM
pic
Attached thumbnail(s) |
jimkelly |
Aug 17 2011, 09:11 AM
notes to myself...
** 3 pulled exhaust studs ** extract busted oil temp sensor ** fix oil leaks |
Mike Bellis |
Aug 17 2011, 09:13 AM
The relay in the 3rd pic looks like a hot start relay. You should be able to connect the FI wiring and a hot to the coil and ECU and it should start. You don't need the relay board.
r_towle |
Aug 17 2011, 09:19 AM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
The relay in the 3rd pic looks like a hot start relay. You should be able to connect the FI wiring and a hot to the coil and ECU and it should start. You don't need the relay board. you will then be running off pure battery with no alternator....keep that in mind. Rich |
jimkelly |
Aug 17 2011, 09:29 AM
thanks guys
it is a 1973 GA 2.0 in a 1975 914 i fried a bunch of distributor wires and it ios easier for me to figure stuff out with engine out of car. |
jimkelly |
Aug 17 2011, 10:20 AM
damn cheesehead tin screws : (
about 1/2 are a bitch. jim |
TheCabinetmaker |
Aug 17 2011, 10:34 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
hand impact screwdriver will back those puppys out like butter. If you don't have one, you need one.
jimkelly |
Aug 17 2011, 11:06 AM
Lo-Fi Version | Time is now: 10th June 2024 - 01:41 PM |
