where can I find this buzzer ...? |
Gustl |
Aug 18 2011, 03:13 PM
914 enthusiast & historian Group: Members Posts: 11,525 Joined: 16-June 04 From: TIROL / Austria Member No.: 2,212 Region Association: Austria |
I'd like to deactivate this buzzer, that humms when the key is in the ignition lock and the door is open
could anybody explain or show me (with glossy pictures with arrows and circles on them (IMG:style_emoticons/default/biggrin.gif) ) where I can find it - I'd like to pull the cable ... I know that I also could pull the cable from the door contact switches, but this would also deactivate the interior light when door is open (IMG:style_emoticons/default/beerchug.gif) Gustl |
SirAndy |
Aug 18 2011, 03:42 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I'd like to deactivate this buzzer, that humms when the key is in the ignition lock and the door is open could anybody explain or show me (with glossy pictures with arrows and circles on them (IMG:style_emoticons/default/biggrin.gif) ) where I can find it - I'd like to pull the cable ... I know that I also could pull the cable from the door contact switches, but this would also deactivate the interior light when door is open If i'm not mistaken, it's on top of the fuse panel. If you drop the panel, you should be able to disconnect it. (IMG:style_emoticons/default/idea.gif) |
tradisrad |
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
Above the fuse box. I think it should be easy to find when it's buzzing. You should be able to unplug the buzzer.
tod914 |
Aug 18 2011, 03:52 PM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
It should be silver and cylindrical if memory serves me right.
Dave_Darling |
Aug 18 2011, 06:49 PM
If this is your 1974, I remember that the one in my car was underneath the passenger's seat, right next to the "Dreaded Seatbelt Inlterlock Relay". A smaller silver can than the relay.
--DD |
dlestep |
Aug 18 2011, 07:14 PM
I am smilin'... Group: Members Posts: 890 Joined: 15-January 08 From: Sunrise Florida Member No.: 8,573 Region Association: South East States |
If this is your 1974, I remember that the one in my car was underneath the passenger's seat, right next to the "Dreaded Seatbelt Inlterlock Relay". A smaller silver can than the relay. --DD ...quoting Dave from 1999 "...the only thing of interest to the running of the car that goes "through" the interlock relay is the big yellow wire from the "crank" position of the ignition switch to the starter solenoid. Other things go "to" the relay, but the parts of interest go elsewhere as well. The smaller can is the "door open" buzzer. I removed mine years ago, it sounded really pathetic and I couldn't stand it. No effects on how the car runs. Some of the wires that go "to" the relay and the buzzer are "hot" when the engine is on. If those wires are shorted to ground you may run into some problems. But if you simply remove the relay and buzzer, and jumper the two fat yellow wires together, you will have disarmed the relay. Make sure that the jumper connections aren't corroded and won't get that way or you'll have starter problems. Make sure that none of the wires are shorting to ground around there (except any brown wires which should be ground anyway)." |
RickS |
Aug 18 2011, 08:55 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
If it's the early car, just. Drop the fuse panel by removing 2 screws open the door and put the key in. The relay will buzz and all you need to do is unplug it. I took mine out 2 weeks ago.
Gustl |
Aug 18 2011, 10:17 PM
thanks for all replies (IMG:style_emoticons/default/pray.gif)
it's for the 1970 six I'll try it this weekend - and let you know |
toolguy |
Aug 19 2011, 04:23 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
thanks for all replies (IMG:style_emoticons/default/pray.gif) it's for the 1970 six I'll try it this weekend - and let you know On a 6, it's the far right can on the fuse tray- just pull it out. it doesn't affect any thing else. . . . looks like a relay but mine has dummy plastic pins and only 2 real pins. . and the base is red plastic. . I recently had to buy one on EBay for my concour car. . everything needs to be correct so even though you don't want it, it has value to someone. . . |
Gustl |
Aug 21 2011, 12:24 AM
. . . looks like a relay but mine has dummy plastic pins and only 2 real pins. . and the base is red plastic. . same here, mine looks identical I looked for it, found it, pulled it out - and now it's all quiet (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beerchug.gif) thanks guys |
Lo-Fi Version | Time is now: 10th June 2024 - 05:20 AM |
