Location for Oil Breather/Puke Can, Will This Work? |
kconway |
Aug 18 2011, 09:46 PM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
Can someone confirm I won't have interference with the motor with the breather can in this location? Not sure I can get the hose to mate up to the oil filler neck though (IMG:style_emoticons/default/blink.gif)
Kev |
Jeffs9146 |
Aug 18 2011, 11:05 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
I am trying to figure out the same problem! I was thinking of putting a 90% elbow on the filler and going into the puke can, but I think it needs to be above the breather.....? Does it??
Jeffs9146 |
Aug 18 2011, 11:13 PM
This is what it looks like without the oil cooler installed and a 3.0L injected motor!
Attached thumbnail(s) |
kconway |
Aug 19 2011, 06:51 AM
I am trying to figure out the same problem! I was thinking of putting a 90% elbow on the filler and going into the puke can, but I think it needs to be above the breather.....? Does it?? Good question on being above. Can't see why it would matter as long as there is someplace for the vapor & mist to collect. Best bet is most of it stays in the oil tank. However, I'm in uncharted waters here. (IMG:style_emoticons/default/biggrin.gif) |
iamchappy |
Aug 19 2011, 07:12 AM
It all happens so fast! Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
That's where i have mine mounted, I have yet to find any oil in it.
jeeperjohn56 |
Aug 24 2011, 05:57 AM
Member Group: Members Posts: 479 Joined: 9-July 06 From: Antioch,Ca. Member No.: 6,407 Region Association: None |
Hey Kev, Where did you get your oil puke can? You is the maker and where did you get it from? Did the AN fitting come with it? if not what size is it? Thanks for the information John
kconway |
Aug 24 2011, 06:10 AM
I bought the breather from Jegs.com part number 52203. It's comes with a AN 10 x -12 flare union on the can, I had to source the 90.
http://www.jegs.com/webapp/wcs/stores/serv...;itemPerPage=90 Here is the can fully plumbed in the above location. I am not using my rear trunk lid torsion bars so I fabbed a bracket that hangs down behind the can and picks up the two mounting studs on top that use to clamp the torsion bar. The petcock is now plumbed down through the engine shelf for emptying the can. I might redo the fitting at the filler neck. I slit the filler neck so I could get clamping pressure on the plastic elbow fitting that the rubber hose is attached to. I've got a weld on AN -12 bung on the way to replace that connection with another AN -12 elbow but that might be overkill for what it does. Kev |
Lo-Fi Version | Time is now: 2nd June 2024 - 06:21 AM |
