Starter Wiring, Push button start switch |
Razorbobsr |
Aug 23 2011, 06:38 AM
Member Group: Members Posts: 282 Joined: 6-June 10 From: Terre Haute Ind Member No.: 11,813 Region Association: Upper MidWest |
Installed a hi torque starter yesterday, and be damned it does start the car[SHOCKED] but the PO has a push button[just in case the normal key switch does not work] system as well. Question: The new starter does not have a place to hook up this wire, I think it should go to the selanoid?????? Correct?? Bob
SLITS |
Aug 23 2011, 06:55 AM
One side of the momentary switch (starter button) is switched hot and the other side goes to the solenoid on the starter.
Razorbobsr |
Aug 23 2011, 07:00 AM
One side of the momentary switch (starter button) is switched hot and the other side goes to the solenoid on the starter. |
SLITS |
Aug 23 2011, 07:12 AM
You have a male spade terminal on your starter and I assume you have two wires running to the starter area. Double male spade terminals are made that that have a female spade (piggy back terminal). Look at the back side of your fuse box and you will see a couple installed. Visit your local electronics store.
All the momentary switch should do is parallel the momentary switch in your ignition switch. |
Lo-Fi Version | Time is now: 4th June 2024 - 06:32 AM |
